Question about Vitamix "1230 Vita-Mix - VM0100A Drink Machine, 64 oz. 2 liter polycarbonate containe"
Blender spin in the opposite direction - Vitamix "1230 Vita-Mix - VM0100A Drink Machine, 64 oz. 2 liter polycarbonate containe"
Kitchenaid ksb540ero coupling
Drill a hole in the rim flange at the top. Engage a screwdriver in the new hole and whack it with a heavy hammer. You are trying to spin the coupling in the same direction it turns when the motor runs. This solution ALWAYS works if you do it right.
Jul 11, 2014 | KitchenAid KSB5 Professional Stainless...
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
I just purchased the cooks 5 in 1 blender today and cleaned it out, per instructions, and put ingredients into it to make pesto. After it was done, I tried to loosen and take off the base (lid) and I have...
I'm afraid when that happened to mine, I ended up taking a sledge hammer to it! I had a very tasty shake inside that I just had to get to! Hence, that's why I need a new base!
Sep 18, 2011 | Cook's Essentials Smoothie Maker Work Top...
On a KSB5WH4 how to remove & replace clutch?
it's reverse threaded. strike clutch firmly in clockwise direction with a screwdriver/hammer. it should spin right off.
Aug 03, 2011 | KitchenAid KSB655 Blender
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Braun 4169 disassembly procedure
4169 blender dismantling. this device is not suitable to be dismantled but this is how I did it. 1 disconnect from the mains. 2 lever off operating lever button at opposite end to hinge 3 insert sharp screwdriver into gap by top lid at same side as cable entry and prise off 4 heat up the casing with an electric paint stripper, wear gardening gloves. 5 when the casing starts to get pliable, insert a driver into the gap above the operating button locating lip and prise away as far as you can 6 do this with the locating peg on the other side 7 work between the two until the whole thing comes apart 8 lever out the motor, it will slide out once loosened 9 wash out the blender drive shaft with boiling water and detergent 10 dry out the body and soak the inside with silicone oil 11 work the blender blade until it spins freely 12 clean everything up and push it all back together 13 if any parts are deformed with the heat gun reheat them to a pliable state and reform them as best you can 14 if it is all loose when its back together, glue the joints with superglue and spray with glue accelerator 15 test it and if it's no good chuck it in the bin and buy a new one 16 but mine works fine.
Oct 09, 2009 | Robot Coupe MP450 Handheld Blender
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 | Blenders
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Vitamix "1230 Vita-Mix - VM0100A Drink Machine, 64 oz. 2 liter polycarbonate containe" Logo
26 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
deton8 von Splosion
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
