Question about Pelco PMCL419A 400 Series 19-inch (483 mm) active TFT LCD monitor, multimode two composite looping, svideo looping and VGA input.
PMCL419 Monitor will not power up.
Having trouble with this monitor, no power light comes on when plugged in.
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Nov 01, 2012 | Computers & Internet
I'm having trouble with my Gateway monitor coming on model # LP2407
Steve
there are so many things that can go wrong, the best thing is to take/send to a professional , or i can take a look at it.
many repairs are the standard capacitor replacement, but many others should be done by someone that has a bit of background in electronics to test all the circuits. For more help i can be contacted at Sprint6@zoominternet.net.
if you would like i can test the unit, at no cost to you, and give an estimate of repair cost once i have evaluated the condition of the unit.
Dec 01, 2011 | Computers & Internet
When turned off for the night, it takes forever for monitor to turn on, the lights on the power button constantly change colors before the screen will work. Is this computer or monitor related?
Maybe your monitor's having trouble getting power. Try plugging it out, and then in again. If that's not working, call you're monitor's manufacturer (if you don't know the number, try searching on the internet). Or maybe that's not the case. Maybe your PC takes time sending the signal to monitor. Call the computer's manufacturer (if you don't know the number, try searching on the internet). Hope that helps,
Daniel
Jun 18, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
When I turn on computer, the blue light comes on and the computer makes sounds as if it is starting and the monitor light is yellow. If I turn the monitor off and then back on, the screen says something...
No input usually indicates the machine is having trouble getting a video signal from the monitor. Check and make sure the monitor cable is connected properly. If you have another monitor also test the machine with another monitor.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Monitor remains black when on
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware (internal electronic part/s) is having trouble powering up the panel/ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring the unit to an authorized service center to properly diagnose & fix it. regards
May 22, 2009 | Acer AL1715 17" LCD Monitor
Plug and play PL716s proview monitor
after almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Jun 19, 2008 | Envision EN-7220 17" Flat Panel LCD...
No Lights, No Power
Hi, it sound like that your monitor is totally dead. You can also try replacing the power cable just for us to know the caused of that issue. and after replacing the power cable it only means that the power supply of that monitor is not functioning well. You can take that monitor to the nearest service center in your area or call your monitor vendor for service.
Tirzo
May 25, 2008 | Gateway FPD2275W LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Pelco PMCL419A 400 Series 19-inch (483 mm) active TFT LCD monitor, multimode two composite looping, svideo looping and VGA input. Logo
79 people viewed this question
Top Pelco Home Security Experts
bobby euell
Level 1 Expert
Leon Peach
Leon Peach
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
