Question about Bushnell Trail Sentry 11-9200 Digital Camera
My camera ser number is920413841 says slp mode what does it mean
Could you please send me the codes my camera keeps going back to slp mode
Canon ixus 132 HD gives error e 32. how do i repare it?
Error codes in the 30 range usually point to a shutter problem. Looks like a repair job
Mar 02, 2015 | Canon IXUS 132 16 Megapixel Compact Camera...
Hi, My office fax machine will not send or receive faxes, or make copies. I recently replaced the toner cartridge, and then the problems began. It keeps saying either printing online, or sending online,...
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
Menu
* (the star on the dialing keypad)
6
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
When my SLP light comes on, my 2002 Altima will not accelerate. When it goes off the car operates fine but the check engine light stays on. what does the car need if the SLP light comes on from time to...
On many nissan altimas I have found bad ignition coils. Usually one bad one will creat a problem. The slp gets gounded through the ignition coil. When the ignition coil is going bad it shorts out other systems. Go to autozone or use a method to retrieve check engine light. If i knew the code it would be helpful. When the car is running rough disconnect one ignition coil with car off. Restart car. If car runs worse that means that coil is good. repeat process. If you have one coil disconnected and the car runs the same that means that ignition coil is not sending spark to your spark plug therefore creating a misfire and making your car run rough. That check engine light is most like likely linked to your slp light. If you find a bad coil using this teqnique replace it, your car will run better. I would like to know your check engine codes and this will determine problem better. If you have a misfire code or a po1300 code that points towards a bad coil
Oct 15, 2010 | Nissan Altima Cars & Trucks
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
Keeps showing on screen, "camera error # "
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
Nov 13, 2009 | Kodak EasyShare P850 Digital Camera
Trail sentry
The SLP stands for sleep mode make sure that you have a san disk memory card this card is what you should use in a bushnell trail camera.Do not go above what gig they tell you in your manual,try a set of new copper top alkaline duraclells.If your memory should only be up to one gig order one from Amazon.com one gig san disks are hard to find at any store.This should solve your problem if it does not call Bushnell.
Pete
Jun 10, 2008 | Bushnell 11-9000 Digital Camera
Codes
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
May 06, 2008 | Funai FDRV90E DVD Recorder/VCR
Speed
I assume by "last longer" you mean more record/play time.  The slp mode is the slower tape speed, which means longer record/play time.  The trade-off with the slower speed is poorer video quality.
As regards tape life, if this is what you mean- I don't know- tape life is often a matter of the quality of the tape itself.
Oct 14, 2007 | Sanyo VWM-800 VHS VCR
Power turns off
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Mar 01, 2007 | Casio Exilim EX-Z500 Digital Camera
Bushnell Trail Sentry 11-9200 Digital Camera Logo
78 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
