Question about Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load Washer - White
Not fill and dont start i change the valve and the presure switch but dont work
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Replace the lid switch. Here is the part you need.
Posted on Nov 04, 2012
Not fill and start
Change the lid switch.
Nov 03, 2012 | Washing Machines
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
I have a craftsman 2 hp air compressor,(model#919.176320) that fills fine,but then will not refill,as if there is presure in the line.The instructions say it will fill to 125lbs,Then refill(cut in...
Hi,lets see what we can do.The air compressor has a relief valve,like check valve .that is not working.The valve reliefs the head pressure so it can be restarted at any time.If pressure is on top of the piston pushing down it can not restart.The pressure in the head on top of the piston is greater than the pressure under the piston.I hope this helps,if you need more assistance feel free to contact me.,,roniecon@gmail.com
Jul 10, 2009 | Air Tools & Compressors
Fuel in the crankcase
Your float valve is sticking - the carb fills up, the fuel runs out through the carb into the engine.
Get a new float valve, until then - turn the fuel off at night.
Jul 01, 2009 | 1988 Suzuki DR 750 S
Machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Jun 27, 2009 | Hotpoint WMA64 Front Load Washer
My mazda tribute 04 want start it trys
there is a fuel rail on your motor in the fuel rail you will find a cap it looks like a tire valve cap
some cars black plastic some light silver metal
find the cap and take it off push down on the schrader valve to see if you have fuel preasure b4 you start changing parts
if it has fuel but it isnt a huge amount
check the fuel presure reg
by having a friend turn on the ignition and while they do that push the valve down if huge fule ammount or huge presure then start looking at the FPR
if it has good or a lot of presure then start by checking the spark
if you can borrow an obd2 tester canadian tire loan a tool and you can borow eithor cheep or free from them
remember you have friends too so dont for get to ask if they have or hnow anyony who might have that you can borrow it
Apr 19, 2009 | 2004 Mazda Tribute
Washer overfilling tub and not shutting off
did it start agaitating? if yes then its your water valve.[where the fill hoses attach to washer from house] if no then it has to do with water level switch.in whirlpool/kenmore washers its very common for the water presure tube to come off of the water level switch.up in the timer console area.other brands dont have that happen as much.some times a mouse has chewed in that presure tube .see what you can do with that.check back with us if needing more help. God bless ,tom
Jan 06, 2009 | Washing Machines
Washing machine
what kind of washer and model # ? Sounds like.. You have a bad pressure switch or the small hose connecting to the pressure switch may be bad or the connection on the switch or tub is linking air pressure I seen where mice had chewed holes in them
Aug 28, 2007 | Washing Machines
Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load Washer - White Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
