Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
I want to extend my 2wire 1000hw wireless signal to another room
Have no or very weak signal in game room. If I move 2wire to game room I lose signal in rest of house. What is the best way to get a good signal everywhere?
  • chris_tenney Jan 07, 2009
    Simple solution. Interested in the router make and model info that he suggests
    Genius:
  • 1,239 Answers
Hi
There are a number of variables that could cause your wireless network signal quality to fluctuate so dramatically. For starters, you might have a problem with range. Typically, the operating range of an indoor wireless network at 11Mbps would be well over a 100 feet — greater than that in an open area like a hall or auditorium.
However, this range can significantly decrease depending on the environment you're in. Most homes constructed of wood and sheetrock aren't too restricting, but a building made of steel and concrete can cause considerable interference. Other things, like cordless phones and microwaves can also hinder performance. So whereas I might be able to get over 150 feet from my wireless router, you might be able to go only 75 feet from your wireless router.
The fact that your transmission rate has a tendency to drop so significantly from time to time leads me to believe that something is causing interference and restricting the range and reliability of your wireless network. So even though you're traveling only 80 feet from the router, you can still be out of the router's operational range.
Here are several options. Consider relocating the router to another part of the room or moving it to another floor altogether. One benefit of cable modems and DSL lines is that you can put them in any room with a phone line or cable connection.
Additionally, placing the router in a higher location could also help compensate for a weaker signal. Using D-Link's diagnostic utility you could also monitor your signal strength when the phone or microwave is in use to check for any fluctuations in link quality.
Honestly, though, I think the best way for you to get around this would be to simply purchase and install a repeater. You see, when you first broadcast a wireless signal it is very strong. As it continues to travel away from its source, the signal strength begins to degrade. The farther the signal travels, the weaker it becomes — until finally it loses its integrity. This is known as attenuation.
A repeater picks up the weak signal, regenerates it and then rebroadcasts it, thus extending the range of your network. This regeneration makes the signal stronger, making it possible to overcome some of the interference you might be encountering.
After you configure the repeater to work with your network, simply plug it in somewhere between the router and your deck. This should extend the range of your wireless network to cover the balcony. Placing it on top of a wall unit might even help compensate for the fluctuating signal on the Dell machine upstairs, as well. You can confirm the performance improvement use D-Link's wireless monitoring utility to measure the signal strength, both before and after the installation.
My personal recommendation for a wireless repeater is the D-Link AirPlus DWL-800AP+. It's an enhanced 802.11b wireless range extender that can operate as a wireless access point or wireless repeater. The unit has a street price of about $65, so it's very affordable. Best of luck!
I want to extend my 2wire 1000hw wireless signal t - question.gifI don't have a very extensive computer background, but I would like to add a wireless router to my home office network. While researching for a router I keep coming across the term NAT. It seems to be important because all of the routers I've looked at list it as a feature, but I don't know what it is or what it does. Could you explain it to me? Thanks!
answer.gifNo problem. NAT is an abbreviation for Network Address Translation. To put it simply, NAT is an Internet standard that lets a local-area network (LAN) use one set of (Private) IP addresses for internal traffic and a second set of (Global) IP addresses for external traffic. The NAT device resides at the point where the LAN meets the Internet.
A NAT inside the router translates any incoming data on that Global address to the destination of the private IP address of the PC that requested it. When it's time to send that data back, the NAT strips away the private IP address information and replaces it with the Global IP address of its destination.
NAT has two primary purposes. First, it provides a type of security for your network by hiding all of your PCs behind a single IP address. Since only the NAT device knows what Internet traffic is going to what PC on the local network, it forces all data packets to be examined before granting them access to the internal network. This helps to protect your PC from unauthorized access by an outside threat; like a hacker or a Denial of Service (DoS) attack.
Secondly, NAT reduces the need for a large amount of publicly known IP addresses by creating a separation between publicly known and privately known IP addresses. This lets a company use more internal IP addresses. S ince they're used internally only, there's no possibility of conflict with IP addresses used by other companies and organizations. Not to mention that it also helps to reduce the IP address depletion problem because all of a company's communications can be routed through just a handful or as few as one Global IP address.
NAT capability can be found in every router on the market today.
Posted on Jan 05, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If I move my 2wire........2wire what?
Posted on Jan 04, 2009
  • bob collins
    bob collins Jan 04, 2009
    1. Is your game room insulated
    2. A repeater may be expensive
    3. Do you use this particular wireless DSL for something else?
    4, I think I have a cheap fix
  • bob collins
    bob collins Jan 07, 2009
    I know this sounds dumb but if it were me, Put you transmitter in a closet making a 1 inch hole in the ceiling to put the antenna in the attic. In the game room, find a hidden spot and get the receiver in the attic with wires going down to device. Nothing to stop it now.
    Genius:
  • 3,422 Answers
HI,
To get a good signal you will have to change your router.That is the only solution.I will let you know the make and model of the router.
  • Priya darshan Jan 07, 2009
    HI,
    A wireless range extender works as a relay or network repeater,
    picking up and reflecting WiFi signals from a network's base router or
    access point. The network performance of devices connected through a
    range extender will generally be lower than if they were connected
    directly to the primary base station.
    A wireless range extender connects wirelessly to a WiFi router
    or access point. However, due to the nature of this technology, most
    wireless range extenders work only with a limited set of other
    equipment. Check the manufacturer's specifications carefully for
    compatiblity information.
    You can use a wireless range extender.The make and the model no.is DLink DWL-G800AP
    for more details you can check out the below link:
    http://www.dlink.com/products/?pid=267
    Few more links to check out:
    http://compnetworking.about.com/od/wirel...
    http://www.netgear.com/Products/Powerlin...
    Scholar:
  • 100 Answers
If you have detachable antenna's you can buy an extension coaxial cable with apropriate adapters Coax (male or female) or (SMA smaller than coax) according to antenna connector and move the antenna anwhere you want to get a beter signal in that location.
  • Anas Al-Mustafa
    Anas Al-Mustafa Jan 04, 2009
    make sure the location of the antenna's is obsticle free as possible to the room you want the signal. you can also attach the wireless on a high point on the wall, if it didnt have detachable antennas
  • 19,396 Answers
You can try a more powerful router , or try a signal rep[eater, both solutions , if working, are good.
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try...
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
Dec 09, 2017 | 2wire Wireless-G 802.11g ADSL Gateway
How can I increase my WIFI range. My internet signal is very weak when I am in my bedroom. Can I increase my range by possibly buying a signal extender.
Try moving the wireless router around and or higher.
If the wireless router is in a different room and the room has concrete walls of foils insulation in the walls, this will weaken the wireless signal. AND/OR
You can connect add a antenna to your computer. Have a look at this device. Normal 0 USB High Gain Antennas www.pricewatch.com/gallery/networking/high_gain_antenna
Oct 25, 2010 | Arris SURFboard SBG900 Wireless Router...
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
I want to identify hardware.
Here is description of the unit , the installation guide and the user guide:
HomePortal 1000HW Router/Modem with Firewall & 1 Ethernet port, highpowered 400mw 802.11b wireless, USB, and HPNA.
2Wire HomePortal gateways include an array of the most common home networking technologies accommodating a variety of service provider and subscriber environments. Flexible networking options include high-powered 802.11g wireless, Ethernet, HomePNAv3, MoCA, and USB.
http://www.2wire.com/pages/pdfs/1000_series_Gateway_Install_Guide.pdf
http://www.2wire.com/pages/pdfs/2Wire_1000_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Wireless
Your can try changing the channel of the wireless signal by accessing your 2wire Homeportal's interface. try changing it using these recommended channels: 1,5,9 and 11. The channel is usually defaulted to 6 which most of the time conflicts with other high frequency devices.Hope this helps. If you are unsure on how to access your Homeportal's interface you just need to know the default gateway of your device. just go to start>run>type cmd>click on ok>then on the blinking cursor just type ipconfig/all and the number's beside the default gateway is the address of your 2WIRE Homeportal.Just simply open a browser afterwards and access those numbers you found on the cmd prompt. and it should show you the interface of the 2WIRE device.
Mar 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
What equipment do I need?
here you go, the short answer. Just a simple re-wire and reconfigure (see attachment).
For the hub I recommend one of these (I have one and it's pretty much plug in play):
http://cgi.ebay.com/TP-Link-8-Ports-10-100-Fast-Ethernet-Network-Switch-Hub_W0QQitemZ330239125851QQihZ014QQcategoryZ51268QQcmdZViewItem?refid=store
May 22, 2008 | 2wire HomePortal 1000HW DSL Modem and...
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
Computers & Internet Logo
171 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
