Question about Mr. Coffee Bvmcejx36
NEED MANUAL FOR COF BVMC-EJX36
POWER IS ON BUT NOTHING HAPPENS
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Mr. Coffee BVMC-ZH1B Power Serve 12-Cup
Hello, yvonne
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
Why won't my coffee single serve brew after cleaning?
You could try what this guy did with his http://www.youtube.com/watch?v=BWP_vn4uHew
Aug 07, 2014 | Mr. Coffee Coffee Makers & Espresso...
I have aLCD HDTV-LC-332D4OU TV
Hi-
Try taking cables from the back of television and turn it off and unplug it for an hour and try turning it back on. is there any lights blinking or flashing in the control panel? try resetting the settings to default as well. Keep us posted. Thanks for using fixya!
Aug 17, 2008 | Sharp Televison & Video
Why does hot plate for pot will not heat-up/mr coffee BVMC-EJX36?
No heat means either the heater element is "Open" or one of the 3 thermostats in Series with the Heater element is open.
you will need a Multimeter to measure... you will also need a phillips screwdriver and a Security torx bit to take the bottom cover off..
From there "CAREFULLY" put your meter on AC volts, and measure across the element... one side of the element has a white wire and the other side is going to one of the in-line thermistors... if you read 120 ish volts, then the element is shot... If it doesnt read anything, then keep one lead on the white wire while you trace back to the next thermistor for 120, then again trace back to the final thermistor... which is thermally connected to the element, that's the final one. If you still have no 120 volt, then the logic circuit is not firing the Relay on the PCB.
I know this because I've serviced one with a bad element... canot find a replacement part so far....
Jun 08, 2014 | Mr. Coffee Bvmcejx36
Brew button flashing
Brewer Head open or water is needed.
The KG5 has trouble reading RO or distilled water, for whatever reason. Here is a site that may be helpful; http://www.mrcoffee.com/service-%26-support/product-support/product-faqs/single-cup-%28brewers%29/bvmc-kg6/BVMC-KG6-faqs.html
Jan 07, 2014 | Mr. Coffee BVMC-KG5 Single Serve Coffee...
My Mr. Coffee BVMC-KG5-00 is not brewing
try going to Mr. Coffee and ask. All you need to do is clean the jet with a paper clip! yeeesh!!! <http://www.mrcoffee.com/service-%26-support/product-support/product-faqs/single-cup-%28brewers%29/bvmc-kg5/BVMC-KG5-faqs.html>
Mar 13, 2013 | Coffee Makers & Espresso Machines
Mr. Coffee BVMC-KG5 made cold coffee
It may be the heating element or thermostat is bad. Try cleaning the heating element and removing any debris.
Download Mr Coffee BVMC KG5 Manual
Feb 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
I Have a Hitachi 42EDT41 and there is no sound and no video. I just put a new Power Supply in (@$90 delivered) and now I get a red standby light in front panel , when I turn it on the standyby light goes...
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV has gone on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
The clicking noise you hear is a protection switch that prevents the TV from starting.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Nov 08, 2009 | Televison & Video
Error code COF 32
i need service manual for the printer minolta di602
Oct 16, 2007 | Minolta Di152 Laser Printer
Mr. Coffee Bvmcejx36 Logo
20 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
