Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
I just changed both belts and the brush does not spin. this is an ongoing problem with this machine.
  • Hoover Master
  • 18,394 Answers
Check the bearings at the end of the brush bar are not seized up
Posted on Nov 04, 2012
3 Suggested Answers
SOURCE: hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Posted on Feb 15, 2010
woobie dog
  • 1273 Answers
SOURCE: brush doesn't spin. motor stressed. burning
Hi, W/D here.
Try to turn the roller brush (beater bar) by hand. It is probably very difficult, if not impossible to move. Lots of things will cause the beater bar to freeze up. Long hair, thread, carpet fibers and such. To remove the beater bar, you'll need to remove the sole plate that surrounds it. It is held on by screws.
Once the plate is removed, lift out the beater bar, paying careful attention to the bearings on the ends of the beater bar in case they come off. Slip the bar out from under the belt. Clean the beater bar, removing anything that might impede the bar's working. Remove the belt and inspect it carefully. Any signs of burning, cracking or other deterioration of the belt is reason enough to replace it. While the belt is off, look at the motor shaft where the belt rides. Clean this area, removing any foreign matter that you find. Slip the new belt over the motor shaft, then slide the beater bar into the loop of the belt. It cannot go but one way, so align the part of the beater bar where the belt fits over it when installing the beater bar. The fit going back in should be tight. place the end of the beater bar that has the belt closest to it into the frame, seating the washer bearing on the end of the beater bar into the slot. Then install the other end in tha same fashion. gently roll the beater bar by hand, making sure that it rolls with some tension, but isn't in a bind. Install the cover plate, and try it out.
Best regards, --W/D--
Posted on Feb 23, 2011
I had just changed the belt and I turned it on to see how it was working , and I noticed that it sounds like the motor is working hard
Take the belt off machine, try machine with the belt off, if motor sounds OK, try spinning the brush before putting belt on, if brush does not spin freely, see what is clogging it.
When brush spins freely, reassemble correctly and try.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 24, 2016 | Kirby G6 Bagged Upright Vacuum
Brush spins once then stops.
I don't know this machine but I'd check the bearings on the ends of the brush to see if they are spinning freely. If it has a drive belt try changing it, if it is an impeller drive check the vanes for damage.
By the way this machine I believe has a 5 year warrenty,
Jun 22, 2015 | Shark Navigator Deluxe Vacuum - Model NV42
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The problem started when i sucked a corner of a rug,now it will not **** very much at all??Kenmore upright progressive
This definitely sounds like your belt is broken. The belt is the part that is attached to the motor at one end, and to the roller brush at the other end. If something gets vacuumed up into the brushes that prevents the brushes from spinning, the motor will continue to try to spin the belt, and the motor shaft will then burn right through the belt, or cause the belt to fall off the motor shaft, preventing the brushes from spinning. On an upright vacuum cleaner, if the brushes are not spinning, it will seem like the vacuum cleaner is not sucking well, but in fact the brushes are just not spinning.
To see if the belt is your problem, while the vacuum is plugged, in turn the machine upside down so that the brushes are facing upwards. Make sure that if your machine has a rug/ floor setting that it's set to carpet mode, and now turn the machine on. Does the brush spin? If no, then this is because the belt has either broken, or stretched out so much that it no longer can spin the brushes.
Here's a link to the owners manual for your Kenmore that will walk you through, step by step on how to to replace the belt.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0403213.pdf
I have also uploaded the instruction manual to the main page on Fixya for your Kenmore 34612.
I really hope this helped you. If it did, please help other people who have this vacuum be able to find this repair on Fixya by rating the repair helpful. You may do this by clicking the 4 thumbs up icons in the right hand corner of the repair. If you have any questions about how to replace the belt, or if the belt is ok and something else is wrong, please just use the clarification request form here on Fixya, and I'll be happy to answer any follow up questions that you may have.
Thanks again,
Chris J.
GoVacuum
Apr 09, 2010 | Kenmore 34612 Bagged Upright Vacuum
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Dear Expert, the vacuum is not working in normal mode but if i use pipe then it works. Any suggestions? thanks khangee
So usually when an upright vacuum works well when using the attachment hose, but doesn't work well when vacuuming on the floor mode, this typically means that you have a belt problem. This is very easy to diagnosis. Turn the machine sideways so the brushes are facing you while the machine is plugged in. Be careful and make sure there's no hair, or clothing near the brushes, and turn the vacuum on. When you do this, are the bottom brushes spinning? If the brushes are spinning, with the vacuum running, put the vacuum brushes down on the carpet as if you were vacuuming, and listen to the brushes. Can you hear the brushes stop when you put the vacuum brushes on carpeting?
If your brushes are not spinning, or if you the brushes stop when you put the vacuum down on carpeting, this is a clear sign that you have either a stretched, or broken belt. Many people equate a broken or stretched belt to loss of suction because without the belt, the vacuum really can not pick up much at all off of the floor. When the vacuum doesn't pick up, many people assume the vacuum has lost suction.
Your roller brush may or may not also be bad. Installing a new belt properly will help you answer this question.
Please see the link below for the owners manual to a model that's similar to the model you posted this repair question under. The belt change will be identical. The belt change instructions starts on page 13 of the .pdf
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you, if so please be sure to rate my repair as helpful by clicking the thumbs up icon in the top of the repair.
If the belt is fine on your vacuum, please also let me know by leaving a comment here on the repair page, I can then go through some more advanced troubleshooting with you.
Thank you,
Chris J.
GoVacuum
Apr 06, 2010 | Hoover Elite U5061-900 Bagged Upright...
Why wont the brushes spin? I have had this machine for about 3 years and it has always worked great, tonight the brushes will not spin at all, it still sprays and sucks up the water. We took the brushes...
In this machine there is no belt. The brushes actually spin by vacuum and in the turbine assembly there is a small wheel bearign which rusts out. You will need to remove and repair or replace the turbine and gear assembly P/N should be 43191009
Feb 10, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Beeter brush not spinning
Hi If the Dyson has a brush protected switch on the left hand side of the machine, then it has a drive belt that can only be replaced by a serviceman or Dyson repairer. If the Dyson doesn't have brush protection, then pop open the sole plate and change the drive belt.
Apr 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Agitator brush wont spin once vacuum is placed on floor
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=573865
Agitator brush wont spin once vacuum is placed on...
Posted by coral7980 on May 05, 2008
This vacuum has given me nothing but problems!!! The newest problem is the brush. I have changed the belt several times, it is a new one now. The brush spins, but as soon as you set the machine in place to start cleaning, it stops and burns up the belt. I need help. I don't want to buy another vacuum!!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem that I can see id that you may have a bad brushroll that doesn’t spin freely, and has either bushings or bearings, a simple test is that take the brushroll out of the vacuum, set in on end and spin the brush, does it spin freely or does it stop, the next thing is to turn the motor pulley on the motor, it should spin freely as well, if either one is not spinning freely or easy then there is your problem, or make sure you have the correct belt size and that is a genuine eureka belt instead of a replacement belt for that model, those are the 3 things that should work for you, if the vacuum is less than a year old – take it to a factory authorized vac dealer and if it is the motor and pulley, it is covered, usually the belt and the brushroll are wear items and are NOT covered, some places however might cover the brushroll as a courtesy to the customer. So feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Don – The Vac Man
Go Ahead. Use Us.
May 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
