Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Model KUD122XX2 F
What should be the water tempeture
How do i lower the hot water tempeture it is way to hot
there should be a grey box on the side of your water heater with a red dial that says hot or warm turn it to the warmer direction to get the temperature to go down
Mar 10, 2016 | Water Water Heaters
Miele front load washer on hot setting does not step on when at main wash after 20min and clothes not hot.works fine on cold wash
are u getting hot water from the water inlet valve or house water outlet? if so u may need to check the water tempeture control knob with a multimeter
Mar 02, 2015 | Miele Washing Machines
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
Fans wont turn on, tempeture gauge will not turn on overheating light
I assume you have made sure the fans actually do turn and aren't seized?
is the water pump working? how many miles has it done? it may have a wrecked impeller and require changing.
It could still be a wiring issue, check for volts and continuity to earth.
Feb 07, 2013 | Cars & Trucks
What turns on the cooling fan on 1999 buick regal?
the tempeture sensor either water tempeture or a/c
Jul 20, 2012 | 1999 Buick Regal
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
Dishwashers Logo
90 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
