Question about Kenmore 24 in. 16293 Built-in Dishwasher
Amana dishwasher adb2200 - Kenmore 24 in. 16293 Built-in Dishwasher
Amana dishwaser adb1100aww won't start is there a fuse in dishwasher
If you are able to set the wash program on the panel but the start does not produce any action, then the door latch is causing a problem. There is a switch behind the latch that detects if door is shut. If this switch is not closing then dishwasher will not start.
Check items 4, 6 and 9 in this diagram. Make sure the mains power is disconnected as high voltages come to the door panel.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dishwasher-Parts/Model-ADB1100AWW0/1268/0130000/W1302287/00002?blt=06&prst=&shdMod=
Apr 19, 2014 | Dishwashers
Amana dishwasher handle
Push the screw driver against the center spring mechanism.
May 14, 2012 | Amana Dishwashers
Amana dishwasher Manual
Amana has many of its appliance manuals on their support site: http://www.amana.com/content.jsp?pageName=CustServ . However, I can't find the above model number.
I found models ADU6000DB and ADU6000DWW. The manuals for these have not been uploaded to Amana's site. I also found the Whirlpool models DU6000XR* and DU6000 with the manual here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20304281.pdf . There is also a Amana Master Clean, DU6000BR, with the manual here: http://www.kitchenaid.ca/assets/pdfs/literature/R0913017.PDF .
I hope that your dishwasher is similar enough that the manuals above help you use your appliance.
Mar 19, 2012 | Dishwashers
Dishwasher will run through cycle but will not pump out water. Amana ADU7000D73WW
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 25, 2010 | Amana 24 in. ADU7000D Built-in Dishwasher
Grinding noise in amana dishwasher
From what I understand, when it grinds, something has fallen into the filter at the bottom of the dishwasher. If you can, look in the filter and see if anything is in there. Eventually, it should stop once the dishwasher has ground up what may/may not be in there. Hope this helps.
Mar 25, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Amana adb1500aww3 dishwasher will not turn on
amana dishwasher keypad has power BUT lights are dim and will not work. tried doing a rest and nothing.
Feb 27, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Door latch problem
how to align the door to center the latch
Aug 26, 2009 | Amana 24 in. ADB1200AW Built-In Dishwasher
Amana dishwasher #ADB2200AWS. Top rack sticks
look for a bend in the rails the rack slides back into
Jul 21, 2009 | Amana 24 in. ADB2200AWS Built-in...
Kenmore 24 in. 16293 Built-in Dishwasher Logo
41 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
