Question about Ruud Handler Air Conditioner
The burner lights for a few seconds and then shuts off
I have a rudd furnace. the burner will not stay lit. Previously It had the same problem, I suspected the flame sensor was the problem, but when I tightened the grounds and connections to the circuit board the furnace worked normally for years. Now it is having the same problem and tightening the connections helps for a few days then it stops working again. sometimes the burner runs for several minutes before sutting down? I am wondering if the flame sensor or perhaps the overheat switch may be at fault? I used to have a manual for the furnace with diagrams, etc (which helped a lot) but don't seem to be able to find it now (years later) any thoughts
  • 70 Answers
Sounds like a bad limit switch in fire box or low airflow check air filter
Posted on Jan 04, 2009
Furnace not staying on
Could be thermostat or safety switch(es) in the furnace. Are you sure that the pilot is staying lit? Are you sure the main burner is lighting? Are you sure the forced draft blower is running, and the blower-detection "flapper" switch is working OK? Any of these safety devices will cause the gas supply valve to close if they are not "satisfied" in a few seconds after the thermostat calls for heat. They keep your RV safe!
Oct 17, 2016 | Dutchmen 2012 Denali 310RES
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Need to replace a RGDA-100A-AR Rudd
it could be a bad flame sensor. if the control board doesn't sense a flame it will shut down the unit
Dec 15, 2013 | Weather King Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
The burner does not stay lit\r\nthe motor runs like and sounds like an airplane then shuts off in a few seconds, with the smell of something burning the thermastat is not picking up the temperature so the...
Hello, looks like the burners are not staying lit Because the furnace is going off on its high limit switch. This could be due to the blower motor being loose on the motor shaft, the blower wheel being extremely dirty, the bearing on the motor can be worn etc. Turn off power to the furnace and see if you can spin the blower wheel by hand, if not the blower wheel will need to be replaced.
Feb 09, 2011 | Heating & Cooling
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have aGibsonGMPN 060-3 gas furnace. The ignitor
May have a dirty flame rod. Look in the burner box at either the far right or far left for a probe that sticks in the flame of a burner. There will be only one wire going to it. This rod is a safety sensor that shuts off the gas if it does not sense flame within a few seconds. If you brush off the rod with a toothbrush or Scotch Brite pad it may take care of your problem. If not, make sure the flame travels from burner to burner quickly. The burner tray may need to be brushed off.
Jan 06, 2010 | Heating & Cooling
Gas furnace wont stay lit
sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Jan 15, 2009 | Central Dual Temperature Heat Gun Kit...
Heating & Cooling Logo
240 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
