Question about Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch
Using Linksys to connect desktop and laptop
I would like to know how to set up my desktop with a laptop so that they both have internet at the same time, using my linksys EZXS55W 5x10/100 network switch. I've been trying to set it up myself, but all I get is either the desktop has a connection to the internet and the laptop doesn't or vice versa. Thank you in advance for any help you can give me.
  • 4 Answers
If your provider uses the connection through Modem, then you can access only one system at a time.
So please check with the ISP provider, however you can share the existing connect by purchasing a third party software.
If the ISP provider use Router to connect the Switch then it should work.
Therefore the problem is with the ISP side.
As a work around solution you can share the network connection to other PC. For Example like file sharing
Posted on Jan 05, 2009
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys router does't really work...
unplug for 10 seconds then replug back in.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
I would like to know the steps to setting up an internet connection using a linksys wrt54g ver.6 using the provider comcast . It is intended for 2 laptops, and a desktop.
if u have the cd that came with your router it will give u step by step dierections. it is very iis to install.just put it inthe drive and do what it says.
Dec 27, 2008 | Computers & Internet
Two computers one desktop one laptop how to connect to internet
Buy a linksys Wireless G and then make sure the Desktop has a Wireless Card into it.
Once you have done this both will have internet Connection.
I advise you stay away from the Linksys by Cisco Routers and I have tried 3 all of them no good.
Dec 18, 2008 | HP Pavilion dv6000z Notebook
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
LINKSYS WIRELESS-G MODEL WRT54G
Have you checked to make sure your internet is connected through your router, and DHCP is turned on. Sounds like you may have internet connection sharring setup through your desktop and it is acting as the dhcp server
Oct 05, 2008 | Linksys Wireless-G WRT54G Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Problems with home networking between desktop running XP (wired) and laptop running Vista (wireless), using DSL broadband (PPPoE) internet connection, Westell 6100 modem/router & Linksys Wireless-G WR
Hi MissGarbs,
Based on your post and description, it would seem that your problem is caused by:
1. having 2 routers on the same system;
2. Both routers performs DHCP server function; and
3. Both routers use 192.168.1.1 as default IP Add.
Your problems are:
a. laptop has no internet access only local network; and
b. you cannot access the router to make changes.
A possible solution. Pls back up your configurations first before attempting changes (or log them down somewhere so if needed you can revert back).
A. Power off and remove all connections to the LinkSys WRT54GS, set it aside for the moment. The objective is to verify/establish Internet connection.
Connect your desktop PC via LAN cable to the Westell 6100. Boot your desktop PC, right click on the networking icon bottom right side in your system tray, click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
tick "Use the following IP address"
Enter values as shown below -
IP address: 192.168.1.4
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS servers: 68.238.0.12 & 68.238.112.12
click on OK, OK, Close.
Power on the Westell 6100, give it time to sync and connect to your Verison. .In the desktop PC, open a browser. Verify that your desktop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support. You need not mention the LinkSys nor the laptop since you have as of the moment a single PC attached directly to the Westell 6100.
If it is all green & go, power up your laptop and boot to Windows. Remove the LAN cable at the back of your desktop and connect it to the laptop's networking port. Do the same configuration ("Use the following IP address") to the networking/LAN card of your laptop.
IP address: 192.168.1.5
In the laptop open a browser. Verify that your laptop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support again. You need not mention the LinkSys nor the desktop since you have as of the moment a single laptop attached directly to the Westell 6100. (This is of course assuming that your laptop has a networking port)
If both the desktop PC and the laptop can now connect albeit individually to the Internet, the LinkSys may now be inserted into the system.
B. Disconnect the LAN connection of the laptop to the Westel 6100 and connect it to one of the 4 LAN ports at the rear of the WRT54GS; do the same with the desktop (use another LAN cable). The LinkSys for the moment need not be connected to the Westell. So in effect you have 2 units connected to the WRT54GS. Do a hard reset on the WRT54GS, with the power on, press on the small reset button at the rear of the unit. Allow it to reinitialize. Open browsers to both laptop and desktop. Type "192.168.1.1", password is "admin" and the username is blank, verify that you can open the LinkSys Web Configuration Utility. On either the laptop or the PC desktop (assuming both can access the same page), on the setup page of the LinkSys Config, change your Internet Connection Type to "Static IP",
Internet IP Address 192.168.1.2
Scroll down to Network Setup,
Change IP Address to 192.168.1.3
Disable the DHCP Server (You can have at any given time only 1 instance of a DHCP server, either from the LinkSys or the Westell, but you can also have NO DHCP server if you are using static addresses.)
Click on Save Settings at the bottom, exit, and close. Verify that the LinkSys can be accessed from any of your browsers by typing "192.168.1.3", if no; go through the procedure again very carefully. If yes, proceed to change the Default Gateway of both the laptop and desktop PC from 192.168.1.1 to 192.168.1.3, all other configurations stand.
In your laptop, right click on the WiFi networking icon (bottom right of System Tray). Click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
IP address: 192.168.1.6
Default Gateway: 192.168.1.3
Verify that you can access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from either the laptop or desktop.
If yes, we can now connect the LinkSys WRT54GS to the Westell 6100. Remove the LAN cable attached to your laptop. Verify that you can still access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from the laptop even without the LAN cable since you are now connected via WiFi.
If yes, connect that LAN cable to the Westell 6100 LAN port, move the other end from 1 of the WRT54GS ‘ 4 LAN ports to the WAN likewise at the rear of the LinkSys.
Verify that you can access the Internet from either computer. At this moment, you have not assigned a security method (WEP, WPA, MAC Filter). Your choice as to what security you want implemented but offhand I would suggest the simplest, MAC Filter since any other would affect speed of your connection.
Additionally, you may want to enhance you browser connection. In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Normally (and perhaps easier for some) would be using the DHCP and not using static. Experience has shown me that static proves to be more stable especially if WiFi is concerned and in your case, only 2 PCs.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 05, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch Logo
263 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
