Question about Nikon D5000 Digital Camera
Need motherboard replacement to make auto focus work
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Call for parts 1-310-414-8107
Posted on Aug 06, 2014
Auto focus will not work on my canon 40d
First of all you need to clean the connectors on both the lens and the camera. Do this by using a pencil eraser being careful not to get bits in the camera or lens. If this doesn't clear the problem is it that auto focus doesn't function with any lens. If that is so then you need a camera repair. If auto focus is only non functional on the Sigma 170-500mm and you can manual focus then the probable problem may be a broken ribbon cable in the lens itself. This will need to be replaced. Usually a quick and relatively cheap job.
Dec 09, 2015 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
18-55mm lens wont auto focus
If the lens will focus on manual focus but won;t on auto focus you may have a ribbon connector failure in the lens. This ribbon continually flexis as the lens moves in and out. Over time this can break and will probably need to be replaced. All good camera repair shop should be able to do this for you and this remady is one of the cheaper repairs to photographic equipment
Jan 23, 2014 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Auto Focus won't work
Another cause of auto focus failure is the circuit connecting the moving parts inside the lens. These "Flexi circuits" move with the lens components and wear out after a while. They are cheap enough to find on ebay and easy to replace.
Dec 06, 2013 | Canon EOS 450D Digital Camera
I dropped my camera and hit the lens and now auto focus does not work
You'll probably need a professional repair. Compare the cost of repair with the cost of replacement. On that lens it could be about the same.
Dec 17, 2012 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens will not auto focus with flash up
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
Oct 11, 2009 | Nikon D60 Digital Camera
I have never been able to auto focus with my Nikon DX 18-70mm
Sure there's a cure! Auto focus on the 18-70 and a D70 has a few switches and menu settings that help to set it up. The switches are on the lens (I'm going to guess this is the one you're missing) and the side of the camera body. If you only have problems with this lens and other lenses auto focus fine, this is really the only thing that could make it not focus. The switch has two settings, M/A and M. It must be in M/A in order to auto focus. Older auto focus lenses don't have this switch.
The other switches and settings would result in auto focus not working with any lens you put on.
If you have problems with other lenses, or if the 18-70 is your only lens, drop a note here and I'll go into more detail on the other settings.
Jul 29, 2009 | Nikon D70s Digital Camera
Sigma 50-500mm auto focus problem
Hi is the manual focus working from inf to close focus and not stoping then it needs a new hsm motor
Jun 07, 2009 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Replaced stk's but I still can't move the red vertically
Did you replace both the convergence ICs ?
The auto-focus won't work properly until BOTH Convergence amps are replaced .
Also you need to replace various resistors along with it .
Feb 25, 2009 | Toshiba 50H81 50" Rear Projection...
Nikon D70 SLR Auto Focus
problem in lens censer replace it
May 14, 2008 | Nikon D70s Digital Camera
Low light with auto-focus
All auto-focus systems need a fair amount of light or contrast to work efficiently. If possible, raise the ambient light if indoors. Search for an area within the desired focusing point with contrast to focus on.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Nikon D5000 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
