Ariston a1600wd trips mains part way through spin cycle
The 30 mA trip blows when the machine is speeding up the spin. This does not happen if the machine is empty. It happens in a rinse, spin and drying cycle.
  • Hilary Pedder Nov 08, 2012
    Problem resolved: it was due to a loose connection allowing power to arc.
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
jason0110
  • 66 Answers
SOURCE: My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Posted on Jun 14, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 135 Answers
SOURCE: Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Posted on Jan 22, 2009
  • 4088 Answers
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
Posted on Oct 28, 2009
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
Blue light and bang from underneath tripped switch and now wont do any cycle ariston washing machine not 2 years old yet
I suspect that the motor or thr heater element has shorted.
Remove the rear cover and unplug motor,remove the motor and check for worn brushes and or short on motor armature.
If it seems o/k, thren disconnect heater, and try washer on spin.
If the motor is o/k, then it should spin.
Hope this is of some help to you.
Jan 04, 2010 | Ariston Technologies Washing Machines
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Oct 02, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Jun 14, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
