Question about U-Line 1175BEV Beverage Cooler
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Posted on Nov 22, 2013
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
How do I correct an OF error?
Krystal,
This has shown up before on Fixya, so I am providing a link to the previous thread and hopefully that will help you.
There is an OF code on my Samsung Refrigerator Model RFG257AA what does...
May 26, 2015 | Samsung RFG29PHD 28.5 cu. ft. French Door...
Can't put shelves back in fridge.
I found the manual online. See if this page helps.
Nov 29, 2013 | GE PSH23PSRSV Stainless Steel Side by Side...
Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Oct 02, 2012 | KitchenAid Refrigerators
How do I remove shelves for cleaning an lg French door refrigerator?
On my Kenmore (795.7555* made by LG) French door, the adjustable shelves are removed by tilting them up and then bringing them forward. The sliding shelves and drawers just pull forward.
Which model LG refrigerator do you have? There may have been design changes between your fridge and mine. Please add a comment with the information for specific instructions.
I hope this helps.
(I didn't bother to give the full model number of my fridge since the directions also apply to the 795.7519* and 795.7554*)
Jul 06, 2012 | LG Refrigerators
Just moved into this house, with a warnock hersey gas fire wh3990 removed the glass for cleaning now it won't come on .I think I disturbed the log placement ,it has a temperature control but even...
When you replaced the glass, you may have not made contact with the glass safety removal switch. In which case, other than the pilot, nothing else will work. When you cleaned the glass, I hope you didn't use a commercial glass cleaner. As they have ammonia in them and it leaves an invisible residue on the glass. When it heats up the residue will turn white and stay on the interior of the glass. If you did use a commercial glass cleaner, remove the glass (which you're going to have to do anyway) and clean it with a 50/50 solution of vinegar and water. Then dry the glass thoroughly with paper towels.
The glass safety removal switch is generally at the bottom of the firebox opening right under the glass, In fact the glass will rest on it. Once everything is cleaned (if necessary) and reassembled. Be sure that after the pilot is lit, the gas control knob is turned to ON. If you have a wall switch that tunrs the burner ON & Off, it will now take over.
Hope this helps you and thanks for choosing FixYa.
Sep 21, 2011 | Heating & Cooling
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
The plastic drawers and shelves on my frigdaire break very easy
lube plastic with silcone spray after cleaning . the clips can be orderedfrom whirlpool or any parts dist. hope this helped mm
Dec 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to get the glass front back on oven door of Whirlpool range
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.
1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.
2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.
3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.
4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.
5: Replace door on Range Unit ande get cookin again!!
Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.
Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
Apr 18, 2009 | Whirlpool GBS277PDS Electric Single Oven
U-Line 1175BEV Beverage Cooler Logo
114 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
