Question about Hilti 3431126 SF 144-A CPC Drill/Driver
How change the chuck on hilti 144 drill - Hilti 3431126 SF 144-A CPC Drill/Driver
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
  • 123 Answers
SOURCE: How do i replace the jacob chuck on a hilti hammer
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Posted on Aug 08, 2010
  • 8404 Answers
SOURCE: how do you remove the bit from the chuck of a TE
Slide the collar on the chuck to the rear (toward the handle)
Posted on Nov 22, 2010
  • 123 Answers
SOURCE: Which hilti drill uses the 00070640 chuck
I am pretty sure it fits the TE-14 and TE-15.
Posted on Jan 21, 2011
How do you remove a stuck bit in the chuck of a TE 17 Hilti hammer drill?
Hilti TE56 SDS max stuck chisel remove - YouTube
? 7:10
https://www.youtube.com/watch?v=rmpvYuEvbIk
Jun 22, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel in Hilti demolition hammer. Same can be made for ...
Hilti SFC 22 A chuck removal and Makita chuck replacement - YouTube
? 7:12
https://www.youtube.com/watch?v=gkjBs0f0upg
Sep 15, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how I removed Hilti SFC 22 A cordlessdrill chuck. I replaced genuine Hilti ...
Hilti TE76 stuck chisel remove and repair - YouTube
? 12:53
https://www.youtube.com/watch?v=v3ckL1lQ-2E&vl=cs
Nov 26, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel for Hilti Te76 demolition hammer. Same can be ...
How to disassemble and find problem in for Hilti TE 7 C rotary hammer ...
? 17:45
https://www.youtube.com/watch?v=4yY97AAHPO4 Feb 7, 2017 - Uploaded by Power tools fix
In this video you will see how to find problem in Hilti rotary hammer drill TE 7 C -~-~~-~~~-~~-~- Please ...
remove stuck bit in the chuck of TE 17 Hilti Google Search
Jun 12, 2018 | Hilti Drills
Where can buy hilti sf 144 switch
GO TO http://www.us.hilti.com/holus/page/module/product/prca_catnavigation.jsf?nodeId=-71302
Mar 14, 2012 | Hilti 3431126 SF 144-A CPC Drill/Driver
Need a new chuck for a tm8 hilti drill
The TM8 was only manufactured from 1984-1986. Parts have not been available in around 15 years. The TM8 had HIlti's version of the Joacob's chuck. It tightened the opposite way from a standard chuck. It had a tendency to fall apart and come off.Hilti revised the chuck two to three times but eventually did away with it after three years.
You might be able to find one on Ebay.
Sep 18, 2011 | Hilti Drills
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti 3431126 SF 144-A CPC Drill/Driver Logo
66 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
