Question about Dishwashers
Dishwasher keeps tripping electric
Thankd for your answer but i have no idea what a disposer is and dont know where to look, Dishwasher is integrated
    Sergeant:
  • 311 Answers
The sink disposer,air gap is on the sink
Posted on Jan 04, 2009
My dishwasher keeps tripping the eletrics when I switch it on !!HELP
Something in the dishwasher shorted out. Likely there is a leak somewhere. This assumes this developed recently.
It is possible the relay that controls the heating element is fused closed keeping power to the element continualy.
If it was a new install, the dircuit branch may be inadequate.
Dec 22, 2011 | Dishwashers
I have a aeg 43070 vi dishwasher It keeps tripping the circit breaker on the house fuse box . I have reset the leak cutout by dipping the dishwasher back and stopped the warning sound,but went for about a...
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Mar 21, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
My disposal only works when the dishwasher is
You say that the disposal only rotates when the dishwasher is running? Are you saying if you turn the disposal on it will not work unless the dishwasher is also on and then it rotates? If you have an on/off switch for the disposal it should at least try to turn when you turn it on. On the bottom of the disposal is a red reset button. If the disposal will not come on push that reset button to reset the breaker. This may solve your problem once you get the disposal running and clean it out. If it trips again something is lodged in the unit and you must clear it out. Turn the power off at the service panel before attempting this. It may also be getting power from a GFCI receptacle. Check the ones in the kitchen to see if they have tripped. Reset them by pushing the red button, and see if that fixes the problem. The drain line from the disposal may also be clogged. Get a bucket and remove the drain line from the disposal and check for a clog in the line and inside the disposal. If you find none then move to the trap under the sink. You may find one of these clogged. Use ice to sharpen the disposal blades and keep the unit fresh at least once every 3 months. Just put ice cubes in the unit and turn it on for about 15 seconds.
Jan 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I've got a GE dishwasher, a GSD2800. It's giving a C4 code and it just won't drain the water. I turned the breaker to it on and off, shut off the water supply and tried to cycle it but no luck. I can...
If this is a new install where there was no dishwasher before. Or if your garbage disposal has been replaced. Then the plug in the garbage disposal inlet for the dishwasher drain may still be in place. You will have to disconnect the dishwasher drain and see if the inlet is clear. If not the garbage disposal will have to be removed, the plug punched out and then reinstalled. Good Luck!
Jul 24, 2009 | General Electric GSD2400NWW Built-in...
Whirlpool dishwasher chopper blade
you can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
Mar 31, 2009 | Dishwashers
My dishwasher keeps tripping the gfi outlet
DISHWASHER SHOULD NOT BE ON A GFI CERCIUT. THATS YOUR PROBLEM . SHOULD BE A DEDICATED CERCIUT BUT IF NOT JUST INSTALL A REG OUTLET DONT WORRY THE DISHWASHER WILL TRIP THE BREAKER IN YOUR PANEL IF THERE IS A SHORT WITH THE WATER.
Dec 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
DISWASHER KEEPS BLOWING THE MAINS TRIP
FOUND SOLUTION...THE LITTLE CAPACITOR THING THAT SMOOTHS OUT THE FLOW OF ELECTRICITY TO MACHINE WAS BROKE. COST £5.00 FOR GENUINE HOOVER PART. FIXED EASILY TAKES ABOUT 3 MINS.....SORTED
Mar 25, 2008 | Hoover 24 in. HD83M Free-standing...
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
