Question about Electrolux Lux 5500 Canister Vacuum
Cant fit vacuum bag in electrolux cannister 3 vacuum
  • Electrolux Master
  • 18,394 Answers
You can dowload the manual from the link below
http://www.aerusvacuums.com/support/manuals/
Posted on Nov 04, 2012
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
SOURCE: Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
  • 97 Answers
SOURCE: oxygen 3 will not turn on
This is often caused by a failure of a fuse on the Sumo board, or occasionally by a failure of the cord reel. I just posted a rather extensive set of instructions on how to check these things as a response to a different thread, but I will repost them here:
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Posted on Jul 31, 2008
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
Electrolux vacuum cannister bag is not full, but vacuum will not stay on.
How long does it run when you plug it in....or does the on and off switch not work?
Jul 27, 2011 | Electrolux Guardian Bagged Canister Vacuum
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
Dec 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Can't get dustbag to fit
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
Apr 10, 2009 | Electrolux Harmony Canister Vacuum -...
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Lux 5500 Canister Vacuum Logo
47 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
