Question about Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop
Induction error 4
I keep getting error code 4 when switching on the induction
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Electrolux Induction Cooktop error code E99
Hello Cecilia, thank you for your post!
If you are receiving an error code E99 on your Electrolux Induction Cook-top, it typically relates to a communication failure. If switching your breaker off and on did not resolve your issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Best regards, Z.
Apr 21, 2014 | Cooktops
INDUCTION STOVE
I have Bajaj Induction Cooker MAJESTY ICX 2 model. While it is working suddenly the display shows E4 and heating stopped. the on/off switch also not functioning. Pl. tell me how I will repair the cooker and what spares are required for repairing.
Thank you,
Susanta Banerjee
banerjeesusanta8@gmail.com
May 27, 2013 | Max Burton 6015 Portable Induction Cooktop...
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop Logo
64 people viewed this question
Top Kuppersbusch Cooktops Experts
Colin Stickland
Colin Stickland
Gil Shultz
Bill Boyd
Are you a Kuppersbusch Cooktop Expert? Answer questions, earn points and help others
