Question about Kenmore Dryers
Drum keeps spinning after dryer door is opened
Suddenly the dryer drum does not stop spinning when the dryer door is opened. The drum used to stop when the door was opened.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 04, 2012
  • 236 Answers
SOURCE: Dryer drum does not stop when door opened
You need an new door switch
Posted on Sep 18, 2009
  • 41 Answers
SOURCE: Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Posted on Nov 18, 2008
  • 17 Answers
SOURCE: when the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
Posted on Jun 09, 2009
localwonder
  • 6784 Answers
SOURCE: Hi, My dryer suddenly stopped drying. No power to
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting...
Posted on Sep 29, 2009
  • 51 Answers
SOURCE: My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Posted on Dec 23, 2009
How do I stop my dryer from spinning?
Could be bad timer but check the timer knob first have seen them crack so they are not pointing in the right direction
Dec 09, 2015 | Dryers
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Open the door on dryer the drum still spinning and wont stop
Hi, You need a new door (switch) that turns the dryer off when you open the door. Replace it.
Jul 21, 2011 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Doesn't spin freely, works for about half a cycle and stops spinning. won't turn back on or spin good until it cools for a few hours. then you might get another half cycle or so out of it.
open the dryer door and maunually spin the drum around. if it spins relatively easily, then it sounds like the drive motor is going bad. the windings open up and it stops. sounds like you need a new motor. it may be cheaper in the long run to get a new dryer
Oct 20, 2009 | Whirlpool Dryers
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
May 14, 2009 | Dryers
Dryers Logo
185 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
