Question about HP PSC 1610 All-In-One InkJet Printer
Cant print from my computer. am using a 1610 all in one printer. the LCD screen says printing but i cant get anything else to work on it
  • hsinyismith Jan 05, 2009
    cant print from my computer. am using a 1610 all in one printer. the LCD screen says printing but i cant get anything else to work on it and the printer shows no MECH mode
  • imconnie2 Jan 06, 2009
    will print 1/2 page and lock. Won't allow me to delete. Sometimes, not all, can cut printer off completely for 5 minutes, turn back on and it'll work for a few prints. Of course, when you're doing multiple projects as I usually am, you have to go back and re-request print jobs.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
I AM PRINTING FROM A DOS PROGRAM, USING A HP LJ 6P I AM NOT ON A NETWORK PRINTER IS PLUGED INTO ONE COMPUTER MY PROBLEM IS WHEN IT PRINTS A ONE PAGE DOC THE LAST THING IT PRINTS IS FORMFEED HOW DO I STOP...
Is the formfeed in the document itself? The printer won't print a formfeed by itself without being told to do so. Of course, if there is no formfeed in the document, then the printer won't print anything at all, just leave the document in memory.
Feb 25, 2014 | HP PSC 1610 All-In-One InkJet Printer
Does not print anything
You need the device driver so that Windows can communicate with the printer. Try the Samsung website and look for Drivers for the ML 1610. Or try running Microsoft Update.
Nov 30, 2013 | Samsung ML 1610 Laser Printer
Why cant my print out be print? There is no light on TONER SAVE. So what does it mean? Please help.
have you run out of toner?
disconnect printer from your computer
do a test print by holding down the cancel button until both green lights start to flash.release button and wait for a test print.
Oct 27, 2010 | Samsung ML 1610 Laser Printer
When i plug an sd card into my hp 1610, the pictures are very very slow to show up on my computer screen, and when they do show up it doesn't want to print them. The copier still works fine. Is the problem...
USB ports on a computer are either:
* USB 1.1 -- up to 11 megabits/second
* USB 2.0 -- up to 20 times as fast as USB 1.1
So, be sure to connect your printer to a USB 2.0 port on your computer, to get faster file-transfer.
As to the "does not want to print", what error-message(s) are produced?
If you copy a picture to your My Pictures folder, can you right-mouse-click on the picture, and "print" from there (after removing the SD card from your printer) ?
Jan 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
Jun 15, 2009 | HP PSC 1610 All-In-One InkJet Printer
Can I download the easy print software for my Canon 1610 printer"
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
Canon UK - Easy Printing
Download Library - Canon USA
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 16, 2009 | Canon Axis 1610 Print Server
Won't print from compter.
dude! follow instructions given int he quick start guide. you need to install driver and software correctly. so every time you switch on your pc and printer, you can see a message in the quick launch menu "HP deskJet F2100 series is ready". now you can use your pc to print.
Jul 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP 1610 - Skipping Lines when printing w/carriage return
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Trying to print from camera to printer
Run these checks. Will the printer print via the computer yes/no If yes - check the software set up- if necessary reinstall the the extra software for printing and reading cards.
Sep 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
