Question about Dryers
Fault code f2 miele T4839C tumble dryer
Working for 5 minutes it stops and says problem F2 contact engineer I tried this on 3 programs
the dr
  • 447 Answers
SOURCE: Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Posted on Oct 03, 2007
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
protek480
  • 1723 Answers
SOURCE: dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
Posted on Jul 02, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
  • 3 Answers
SOURCE: f2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Posted on Jan 05, 2010
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
Eror f2
F2~37 is a Drum Process Control error, if it does not clear with a couple of power-up cycles...then the only thing you can do is wait for a suitably qualified Engineer to fault check the Drum unit and sensors.
Just trying to clear the error code within maintenance program will not solve anything until the root cause has been found as this code will repeat and continue to stop the machine until it is dealt with.
Lucas
Jul 07, 2011 | Office Equipment & Supplies
I turn my indesit is70c tumble dryer on and after a minute it trips the rcd. I then reset the rcd and turn it back on and it runs for about a minute and then trips the rcd again. Can anyone help me with...
this could be the hater or the motor but sometimes just chafed wireing
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
We have a full video library on appliance repair video’s
Jan 03, 2010 | Dryers
Tumble dryer borke
Common faults -
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jul 13, 2009 | Miele T8005 Tumble Dryer
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
Hoover TCE660 tumble - no heat
Common faults -
Jan 12, 2009 | Hoover HDC6 Electric Dryer
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Dryers Logo
1,044 people viewed this question
Top Dryers Experts
