Question about Dishwashers
Fault code f2 miele T4839C
Working for 5 minutes it stops and says problem F2 contact engineer I tried this on 3 programs
Rotu
  • 175 Answers
SOURCE: Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Posted on Nov 06, 2007
SOURCE: F2 fault
I had a problem with F2 fault and all lights flashing when the dishwasher is just plugged-in (and drain motor starts running). I thought I was in for a few hundred bucks, but thanks to greendude (an expert here) I eliminated the problem myself. The problem was in water supply pipe connection that started leaking and the bottom pan was full of water setting-off drain pump.
Posted on Apr 07, 2008
RescueTech
  • 145 Answers
SOURCE: f2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Posted on Feb 08, 2009
SOURCE: G879 Miele dishwasher does not startup
I found the solution by phoning Miele. You just have to reset as follows: switch on with program 2 and 3 pushed in. Then push top solo twice. Switch off and on again. The Miele is ready to go.
Posted on May 07, 2009
  • 1382 Answers
SOURCE: mY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Posted on Sep 10, 2009
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
Eror f2
F2~37 is a Drum Process Control error, if it does not clear with a couple of power-up cycles...then the only thing you can do is wait for a suitably qualified Engineer to fault check the Drum unit and sensors.
Just trying to clear the error code within maintenance program will not solve anything until the root cause has been found as this code will repeat and continue to stop the machine until it is dealt with.
Lucas
Jul 07, 2011 | Office Equipment & Supplies
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Dishwashers Logo
337 people viewed this question
Top Dishwashers Experts
Owen Barnes
