Question about Acer Extensa 4620 Notebook
Blank screen on start up on Acer Extensa 4620
On booting up the screen remains blank ie just black but you can hear the laptop going through the start up but nothimg appears.
  • therimmers Jan 04, 2009
    problem solved took battery of left for a couple of hours reconnected powered on hey presto working screen
  • The HP DV7's had faulty graphics video cards made by Nvidia. This is a known issue that you will see documented all over the internet. The guys athttp://www.generalsystemsconsulting.com fixed mine at a reasonable price $125.00 includes return shipping back to me.
    New Friend:
You could download a bootable disk, and use a dvd or a usb drive. whenever it starts up, reapetedly click F2, go to "boot" and use F5 an F6 to move the usb or dvd drives first
Posted on Dec 31, 2012
    Sergeant:
  • 279 Answers
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Posted on Jan 04, 2009
    Novelist:
  • 176 Answers
If you're hearing the fan, HD and see power lights but still see no display even the BIOS splash screen display then confirm toggle (fn key) to external monitor. No display in either internal or external monitor indicates board level failure.
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
Acer Extensa 4630. The screen is blank but the computer is running. The acer screen appears upon start up but then the screen turns black. Any suggestions?
have you enabled "standby"mode,you usually have an option when shutting down.Either this or go into settings and make sure you havent adjusted sleep mode for the screen
Sep 10, 2010 | Acer Extensa 4620 Notebook
Screen is blank? can you check this computeR? exentsa acer model #jalao
If your system seems to be going through its normal boot routine, look at the screen from several different angles. If you see 'ghosting' then it is likely the display backlight or the inverter for it that has failed. If you have, or can borrow, a standalone monitor, plug it into the VGA port of your notebook. If you still see nothing, it may be only that the external port must be turned on in your CMOS setup but the external monitor should at least show text during the boot routine.
Apr 17, 2010 | Acer Extensa 4620 Notebook
Booting Systems Down
these types of problems are very complicated. I being a tech can fix very easy if I have the pc in front of me but to explaine to someone how to do it is very detailed. The 1st thing that any good tech would suggest is to start in safe mode and remove uninstall the software and hardware you installed. then reboot and go from there.
Sep 24, 2009 | Acer Extensa 4620 Notebook
When i login but the screen is blank how do i get to the desktophow to reboot by not deleting any folders?
before run and booting the OS hold and press F8 on top keyboard then run as safe mode then make a restore default windows.good luck
Jul 19, 2009 | Acer Extensa 4620 Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 4620 Takes 3 Minutes to get past Cmos screen
goto bios by pressing F2 or Del while booting...
then in boot priority change first boot device as hard disk...
Jan 15, 2009 | Acer Extensa 4620 Notebook
Extensa 4630z boot mrg is missing no restart programs
  4620z. To redo your computer Hard drive to the state that it was in when it came out:
Download the Post Ace disk Formatter CD ISO image.Last one on the list. I believe that is the "installCD" software
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Dec 13, 2008 | Acer Extensa 4620 Notebook
Acer 4420 Screen going blank
Un-take "Turn off monitor after 5 min" from Power options in Control Panel.
Nov 16, 2008 | Acer Extensa 4620 Notebook
Acer Extensa 4620 Notebook Logo
877 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
