Question about Electrolux EOB6636X Ultrafan Electric Single Oven
Oven heats up then switches off
When i turn the oven on it will heat up for max of 10 to 15 minutes then will turn off and then will only turn back on when the oven has cooled down help much needed
  • 2 more comments
  • an0214 Aug 07, 2008
    Hi we are experiencing same problem, the oven gets really hot and then shuts itself down and after a few minutes it springs back into life. Can we replace the thermosat ourselves?
  • mikewalker May 11, 2010
    Hi ?Tresilla, I have a
    Electrolux Oven EOB6630 and having the exact same problem, /i know nothing about ovens but cant afford an electrician. What is the best thing to check first? A few people have said thermostat, how can i replace this and how easy is it?
    thanks
    mike
  • Anonymous Mar 12, 2014
    oven starts to heat up but then baking light starts to flash and oven will cool down and you can't turn it back on till it cools off
  • Anonymous Mar 24, 2014
    oven heats up , then shuts off and I have to wait till it cools down before I can start it back up
    President:
  • 1,462 Answers
There is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
Posted on May 20, 2007
SOURCE:
Where do I locate the fuses that controls the oven heating.
Hello Pat;
My name is Peter. I am a retired field service appliance technician.
When you go into self cleaning both of your burner element peak at there max temperature, well above 500 degrees F.
1.) Oven Element - Over time the elements will fail. Turn the upper element on. Inspect for sparking where there may be a crack in the element. Turn the upper element off, inspect for any cracks.
If there are no cracks then you lower element is fine.
2.) Each of your ovens have a independent thermocouple. Both may have failed due to the extreme heat. Oven thermocouples will fail on older units.
3.) Lets go to the source. You have what is called a infinite switch in your oven. This switch controls your oven temperature. If this switch fails then your oven will not work.
Ok, lets assume you or a friend are good with tools. With a multi-meter set to the lowest Ohms, In the back of your oven there is a sheet metal cover. Remover the cover, disconnect the two contacts on each thermocouple, and Ohm them out. (Power Off at your breaker box first) You should get a reading of '0' Ohms, anything else the thermal couples are bad.
But, I tend to believe, You have a bad infinity switch. You can also Ohm this out as above with a reading of '0' Ohms.
This component is about $35.00 USD.
If I were still working for Sears Home Services I would charge you $350.00- $450.00 for this service call. Send me your model number and let me see what you have. goodwinpeg@aol.com.
Feb 24, 2015 | Ovens
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
Hotpoint BD52 oven very slow to heat up
You may have one leg of power that is out. First turn off the breakers, then back on. Check it to see if it is better. Then check the wiring from the receptacle, to the plug, to the back of the oven. Look inside the back of it and see if you see any fuses. They could be blown as well. If you are getting some heat (red) then it is an indication of a wiring or fuse problem. Now, one last thought here, if you turn it to high heat does it heat up faster? This one lead it to be in the control switch. Let me know how you do.
Feb 13, 2009 | Hotpoint Ovens
OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Electrolux EOB6636X Ultrafan Electric Single Oven Logo
1,169 people viewed this question
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
