Question about Refrigerators
Everstar ice machine HDIM 120 stop making ice
The water is running, just stop making ice
  • R Omara Nov 03, 2012
    it is not a refrigerator but a stand alone ice machine
VOTIT
  • 2071 Answers
SOURCE: everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Posted on Jul 30, 2008
SOURCE: Problems with Kenmore Side by Side Refrigerator
I had the same problem twice, and both times I had to replace the Solenoid/value part. I went through the troubleshooting guide for the ice maker, which was nicely tucked in the front kick panel, and everything worked fine. It went through the cycles but still no water comes out. I finally had to follow the trail back to the solenoid/value unit. Remove the connectors and plug an A/C volt meter into the wires which go to the solenoid, run the cycle, and if you have 120 volts AC, you should have water coming out of the fill unit (assuming the line is not frozen).
Here's the part I had to replace. again, twice in two years. Don't know if you have the same model, but good luck.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4389177&productGroupId=0046&supplierId=106
Posted on Dec 04, 2008
  • 31 Answers
SOURCE: The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Posted on Mar 13, 2009
SOURCE: ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Posted on May 16, 2009
Karthik316
  • 187 Answers
SOURCE: GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Posted on Jul 25, 2009
Water leaking
Water can fall off of coil prematurely, before it reaches the drain pan, sometimes due to debris on the coil surface, airflow turbulence in the return air box, and in some instances I've never resolved until the machine was replaced. The drain pan could be cracked or have blocked channels that allow water to drain from the rear to the front. It could also have ice on it/freezing up. Some will developed a thin sheet of ice and drip water. The drain line may be stopped up or broken/loose fitting. Some coils have a laminate on the aluminum fins that can deteriorate. Hope this gives you something to check!
Jun 13, 2015 | Everstar Portable Air Conditioner MPK-10CR
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker stopped making ice,
Ice makers are pretty generic. Let's start with the water supply. You are positively getting water to the water valve in the back of the refrigerator? You can check this by disconnecting the copper or vinyl line on the water valve located at the back if the machine. If , you are getting water through this line, then, reach into the icemaker mold to see , if, there is ice or water in the mold. If, there is no water or ice, you have a defective water valve. Checking the water valve is easy, but, not for the faint of heart. Disconnect the leads to the water valve and apply 120 Volts to the water valve, if, the water valve doesn't activate the valve is shot. Sometimes a leaky water valve will cause the fill tube for the ice maker to freeze shut. You can check this by manually, with a flashlight by looking into the tube that supplies the water to the icemaker, if, it is frozen solid, the water valve is in need of replacement. If the aforementioned things are not the problem, get a new ice maker.
Jun 15, 2009 | Refrigerators
take the cover off of the ice maker. there are 2 plastic tabs in the middle of the gear on the ice maker. if one of those tabs is bent or broken, that is your problem. if the tabs are okay, check your fill tube in the back of your freezer that goes to your icemaker and make sure it is not frozen. if both of those are okay, then you may have an issue with your water valve. Joe
Dec 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Everstar Ice Maker
Hopefully you have a filter before the ice maker. Replace this (if you have one) at least every 6 months.
ap
Ice maker not making ice
My ice machine stopped making ice after the city shut off the water line for more than 8 hours. How do I make it start making ice again.
Apr 23, 2008 | Refrigerators
Ice maker will not make ice
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
