Question about Brother MFCJ6510DW AllInOne Inkjet Printer
Out of memory. Not enough memory for the scanning device. Close other programs and try again
All programs are closed and computer and printer/scanner have been shut down for several hours, so hopefully nothing is cached. I only have 4 GB of RAM, is this my problem? Sometimes it will work quite well for a while, and then boom I get this message.
  • 6 Answers
SOURCE: Error: "Back cover is open. Close back cover."
We had this problem. It turned out there was actually a piece of paper stuck in the printer! It wasn't so easy to see it from the rear.
We removed the paper from the front by taking out the ink cartridge first. Turned the printer back on and everything was fine.
Posted on Apr 06, 2009
marketex
  • 371 Answers
SOURCE: How do I get the scanner to properly scan pencil
You have to configure the scanner for the maximum number of shades of grey, usually 256, or more,
if available, rather than black and white, as it apparently is presently set.
If you need more assistance with this, just leave a comment, with the name of the program you use with
your scanner and any other helpful information that will help me help you.
Posted on Apr 17, 2009
SOURCE: Brother (photocopier, fax and scanner machine)
I have fixed this problem on my 7820n printer by brother.
open the back door, then inside there will be a black colored other kind of like door that pulls back away from the roller. on this inner door is a black long thin plastic lever that runs from about the center of the inner door to the right. on the right end of it is a lever that slides along a curved increase on the right side wall. when both doors are closed this right end of the rod or lever moves up to close the gap between what is the sensor. this long thin plastic rod had snapped out of place and when i snapped it back in making sure the spring was correctly installed on the left end of it and the middle part of the rod slid correctly in its groove...the right end of the lever correctly closed the gap on the sensor (when both doors are closed) and the back door open error went away.
So that's how you really fix it!!!!
James Hilliard - Totally super awesome guy! hee hee
Posted on Feb 12, 2010
  • 1570 Answers
SOURCE: When I try to scan a document on the MFC 8460N
HI there
Did you try to check the cable connection by removing and pluging it again. If not please do it.
I believe it is the connection problem, if you can uninstall and reinstall the scanner driver again or repair it using the printer software CD. I might help the problem.
Posted on Feb 23, 2011
elix0411
  • 3530 Answers
SOURCE: Installation of MFC-6490CW scanner driver
Welcome to Fixya
Please click this link and download all drivers and software related to your printer. Make sure to uninstall first all the softwares related to the printer before installing a new one. If same thing will occurs after installing the drivers and softwares, try to reset the machine back to the factory default state. Please see below procedure:
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except the power cord).
  2. Press Menu.
  3. Press the up or down arrow key to choose Network and press OK.
  4. Press the up or down arrow key to choose Factory Reset or Network Reset and press OK.
  5. - For MFC users:
    Press 1 for Reset.
    - For DCP users:
    Press + forReset.
  6. - For MFC users:
    Press 1 for Reboot.
    - For DCP users:
    Press + for Reboot.
  7. The machine will restart, re-connect cables once this is complete.
Thank you for using Fixya!
Posted on Aug 24, 2011
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
I cannot get the scanner buttons to work. Nothing is showing up on my system tray to control the scanner buttons. The scanner works fine with software control thru Paperport. I have reinstalled One...
This is usually a symptom of either the basic driver being installed (not the OneTouch 4 software), the destinations for the buttons not being set in the OneTouch 4 software correctly or the monitoring program not being active. (For the X7600, the OneTouch 4 software comes with PaperPort programmed as the default destination for the scan button. If that setting got changed, it could cause the problem.)
The drivers and software are available here: http://www.xeroxscanners.com/en/us/products/drivers.asp?PN=X7600 . Scroll down for the manuals. If you have the basic Xerox driver installed, uninstall it (remove the scanner from the Device list by right clicking on it and choosing uninstall) then disconnect the data cable. Finally restart the computer and then install the One Touch 4 software.
If you have the OneTouch 4 software installed, check if the program is set to run on startup.
Click Start > Run then type "msconfig" (without the quotes) in the Open box. Click OK. Choose the startup tab and look for the Xerox software. Make sure the box is checked. Click Apply after changing the settings and restart the computer.
Next, launch the program (Start > All Programs) and try to launch a scan from the One Touch button panel on the computer. Adjust the settings if needed in the Configuration section of the software (see the manual for screen shots).
I hope this helps.
Mar 29, 2011 | Xerox 7600 Flatbed Scanner
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Computer says it is busy when I try and print out a page, just installed new black ink cartridge and it won't try and print anything now.
1. Check to make sure the black ink cartridge is installed properly.
2. Check to be sure no printer alignment program is trying to run.
3. Right click the printer icon on the tool bar and see if any print jobs are still lingering. Cancel them or Restart them. Printer should pickup and start working from there.
Last resort:
4. Shut down the computer and unplug the printer for at least 1-2 min.
Restart everything paying close attention to any error messages.
If none, the printer should work again provided nothing serious has happened.
Hope this helps!
Oct 17, 2009 | Lexmark X2600 InkJet Printer
Scanner in use
close all the programs that are running and restart your computer. also turn off the scanner and disconnect it from the PC and power. plug it back after 5mins, reboot your computer, start the scanner program and reconnect the scanner. try to scan again. if it fails, disconnect the scanner and unistall the driver, there might be a conflict somewere. reboot your computer and reinstall the software then connect the scanner and try to scan again.
Jun 23, 2009 | Office Equipment & Supplies
Can't install, fails every time.
had this same problem, go to Add and Remove Programs and uninstall "Bonjour" and then run the Kodak Setup and it will reinstall it.
May 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When pressing scanner to computer button nothing happens
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 2500 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
May 09, 2009 | Lexmark X2550 All-In-One Printer
HP zd7188cl shuts off whenever it feels like - sometimes it restarts to shut off later
You can resolve this issue by performing the following steps:
1. Right-Click on My Computer and Click on Properties. 2. Click on Advanced tab. 3. Click on Settings button under Startup and Recovery. 4. Uncheck Automatically Restart. 5. Click Apply and Click Ok.
Jul 12, 2008 | HP Pavilion zd7188cl PC Notebook
All in one lexmark 7170
1.Get the software disk out.
2. Close down your internet connection.
3.Disable the anti Virus Program.
4 Go to Start./printer faxes- click on the printer icon right cliuck remove printer.
go to left panel - click install printer
Insert the Software disk install printer driver.
Restart the machine on the prompt
Jun 17, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Brother MFCJ6510DW AllInOne Inkjet Printer Logo
546 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
