Question about Watches
I have Bulova mans wristwatch gold plated dual-day.On the back it has this written N9 Bulova base metal bezel steel,water resistance.I am trying to find the the value of it.
Mans wristwatch dual-day N9 base metal bezel do not know the year or serial number .Gold plated braslet. Top white, no numbers,Automatic Set-o-Matic
I got a 10 KT acutron it says its plated but a magnet don't stick to parts of it.is there any solid Gold pieces on it. It also says n9
N9 is the date, 1969.
Magnets will only stick to iron and steel (ferrous metals). Gold is none ferrous, stainless steel usually is non ferrous, as it has a nigh nickel content.
Jul 09, 2016 | Watches
Fake or not 18kgold bulova swiss made also says 18k gold plated
it will not be a gold watch as it states gold plated
that is to say that it has a coating of gold electroplated to the base metal and will be about 2 microns thick
check with a jeweller for the fake or not.
Apr 10, 2015 | Bulova Watches
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
I'm looking for the worth of a ladies Bulova watch with 10K Rolled Gold Plate L3 1131948 on the back.
i have a bulova same no. speidel pat. but the serial no. u lookin is different this one is 10kt rolled gold plate back.
Oct 20, 2011 | Watches
Bulova stailess steel 16 Diamond Bezel Chronograph Watch discolored on raised part of bezel like the metal is turning brown?
You can try a polishing cloth to see if this removes the discoloration, or very gently brush it with a toothbrush and mild soap ( very little water) if this does not help you will need to send the watch back to Bulova to their service center. 1-800-228-5682 is the Bulova service center phone number, call them for further instructions. Sometimes the discoloration is caused by certain chemicals found in lotions, soaps and cleaners. Hope this helps! thank you!
Sep 21, 2011 | Bulova 98R107 Diamond Collection...
Need appraisal on my grandmothers old bulova watch, serial # 1518119. It has links as its bracelet and is attached to the watch on its side with clips
Without more information, such as a picture of the watch or more information about the case, it is difficult to provide a value for this item. In general, vintage fancy ladies watches (the kind that are approximately the diameter of a U.S. nickel or smaller) are not very collectible. As recently as a few years ago, these were bought and sold in bulk for only a few dollars each. In nice cosmetic condition and running properly, a Bulova ladies fancy dress watch in a steel or gold-plated case might retail for between $15-50 at an antique mall. They might sell for somewhat more at a jewelry store that stands behind the accuracy of the movement, but because the inventory of these watches is so large and demand is fairly small, prices for these watches remain much more modest than similar age men's mechanical wristwatches.
Some valuation exceptions do apply. Certain brands of watches, such as Rolex, IWC, Blancpain, and other premium brands, are worth much more than common brands like Bulova. Ladies watches with sweep second hands, as opposed to fancy watches that just have hour and minute hands, are more desirable and are also worth somewhat more than average. Also, watches in solid gold, platinum, or silver cases--or watches with diamond chips or ornate cases--are also worth at least their "melt value" as scrap metal or have an independent value as fine jewelry. All precious metal cases must be labeled; if they are not labeled on the outside of the back cover, they should have be marked on the inside of the back cover (you'll need to carefully take the movement out of its form-fitted case to see this). Be aware that "14k RGP" or "rolled gold plate" on the case means it is not solid gold. Similarly, cases that are "warranted" for 10, 15, 20, or even 30 years are also gold-plate, not solid gold.
Today, with the increase in gold prices, many people have been buying these watches to melt down the gold-plated or gold cases for their gold value, throwing out the watch movements and watch bands. This may have a long-term impact of raising the value of these watches in the long term, as this is decreasing the supply of available watches of this type (it's also frustrating to watch collectors to see the watch movements discarded, as these are valuable sources of replacement parts that are no longer made). However, tens of thousands (more likely hundreds of thousands) of these watches exist in the United States alone, so there is little likelihood that these will become scarce in the immediate future.
May 09, 2011 | Bulova Watches
Looking for user guide for model 4511 Desert Falcon Zodiac watch
Clearly a screwdown crown is better for water resistance but most watches maintain a seal without it. I wouldn't test out the 100m claim but it should be safe in the pool.
Apr 29, 2010 | Watches
Appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
Sep 14, 2009 | Watches
Watches Logo
62 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
