Question about Amana 24 in. ADB1500AWS Stainless Steel Dishwasher
The detergent cup won't lock in place-model # GSD5330D02WW
Dishwasher model # GSD5330D02WW. We ordered a new detergent cup shaft. When we took off the old one, the detergent cup spring came off. We can not figure out how the detergent cup spring attaches. Can any help? We don't even know if this will fix our problem but we thought we could start there.
Maytag dishwasher detergent cup won't open on it's own...
The detergent dispenser is sold as a complete assembly, it's reasonably easy to replace, it just unscrews once you have removed the front panel of the dishwasher,
Mar 07, 2012 | Dishwashers
Detergent dispenser problem
Is it new? Even if it was or wasn't, I strongly feel that you probably didn't set something properly. Read the manual it came with, particularly the troubleshooting section. Not a big problem. Let me know how it goes. :)
Jun 29, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My detergent cup won't open. Not sure if the little metal clips are positioned correctly.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
heatman101
May 10, 2011 | GE Dishwashers
Where do you put the dish wash detergent for my dish washer!
Hi, for most dishwashers the detergent cup is behind a little door in the door of the dishwasher.. snap open the door and place the detergent in the cup while the door is open and down, then close the little door and then close the dishwasher door...
then you are ready to roll...
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | Dishwashers
The place where u place the soap won't let all the soap out why
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Jun 20, 2006 | Maytag PDB3600A Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Amana 24 in. ADB1500AWS Stainless Steel Dishwasher Logo
94 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
