Question about Acer Aspire 9300-5349 Notebook
Acer aspire 5349 flickering acer black screen then blank screen over and over
topshy
  • 19 Answers
SOURCE: Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
In most cases like that,where we have screen flickering,first look at the graphics card maybe the signal flex from the back of the screen is well fixed on the motherboard.then if it is well fixed on the board you will need to look at the signal board at the back of the screen maybe it is well fixed if it is not well fixed then fix it properly to solve ur problem then if the problem still persist then u will need to disable the VGA in device manager.to get to device manager u will need to open my computer and after that, u can right-click on it and then click on propertise then click on hardware and then click on device manager where u can disable the VGA.
Posted on May 29, 2008
kyo_ajis
  • 68 Answers
SOURCE: Blank Screen Acer Aspire 5920
im afraid that your screen is broken, but try to move the screen foward and backward littlebit, my friend also have the same problems and only by contact local support using his warranty the problems fix, you may open your laptop to see if something wrong with the wire but i think its not practically good.
Posted on Jan 28, 2009
  • 10 Answers
SOURCE: SCREEN IS BLACK
i have this problem 2 days ago.. and this works on me... maybe on your's too
you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios
how to flash the bios:
STEP 1.download the AA1 BIOS from this link:
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
2. extract the file
3. rename the file 3309.fd to zg5ia32.fd
4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2
A. make sure the power cable is in
B. the laptop is turned OFF
C. Plug the usb stick in!
STEP 3:
Press and HOLD down the FN and ESC key together
then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds
release the buttons and the power light will start to blink
let the laptop run and DO NOT PRESS anything this can take upto 8 mins
when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Posted on Jun 15, 2009
  • 1684 Answers
SOURCE: Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 08, 2009
will-raven
  • 83 Answers
SOURCE: Screen problems on Acer Aspire 5740
I don't know that it is a common fault with this specific model, but laptops in general have this issue mostly due to a dying LCD power inverter. It is typicaly located at the bottom of the LCD screen and costs between $30 - $75 dollars for the part, and usually $75-$150 for someone to replace. If you like the laptop it is usually worth it to have replaced. You can also hook up a monitor to the VGA port on the laptop and then go into your display control panel and enable 2nd monitor to use it instead of your laptop lcd.
Posted on Apr 30, 2010
How do i change the screen resolution using the fingerpad on my acer aspire 5349 laptop?
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display and click Settings and you can change the screen resolution by sliding the bar over. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768.
Depending on your operating system you might see link for Screen Resolution without actually opening the display.
May 27, 2012 | Acer Aspire 9300-5349 Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Monitor flickering
Hi
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 9300-5349 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
