Question about Lowrance 5300C GPS Receiver
Lowrance 100 works lowrance 500 dosen't [dropped] swap chip?
Lowrance airmap 500 love it , but dropped and broke .Now Ihave a used airmap100 can I put 500 chip in 100
Thank you verrymuch
Nicholas Hillman
    Scholar:
  • 30 Answers
You cannot use a chip from the AirMap 500 in an AirMap 100. The AirMap 100 is not compatible with the mapping used with the AirMap 500 and the AirMap 100 does not have a memory card slot.
I suggest you use the AirMap 100 while you think about getting the AirMap 2000 or some other newer aviation GPS unit.
Posted on Jul 10, 2009
3 Suggested Answers
  • 30 Answers
SOURCE: Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Posted on Jul 14, 2009
SOURCE: HOW CAN I GET A
Go to LEI Extra and pay US $49 plus $20 or $30 and then the availability ceases in July 2011.
Navico/Lowrance are leaving everyone without support. So much for supporting the undergod and trying to encourage competition.
I will say that I have had 3 Lowrance Airmaps and found them much more suitable to my needs than the Garmin handheld although I have 2 x Garmin 430 GPS in my aircraft.
Finally, for me in Australia a one time Lowrance SD card upgrade will cost not only US $49 but I think another US$50 postage. Carrying a Lowrance SD card is about two times more expensive than two hard drives.
Posted on Mar 24, 2011
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Put in used steering colum and truck turns over but dosen't fire up
if you have a chip in the key the different key wont work with the ECM so youll have to have a dealer flash the ECM
Apr 16, 2013 | 1997 Ford Expedition
I have an older Lowrance, Model X65, which until a few weeks ago worked as if still new. I hadn't used the boat for the past few weeks and when I did the Lowrance screen now has a large brown spot in...
You need to contact Lowrance about the repair.
My really older, but loved, unit failed and Lowrance pointed out that techonlogy is SERIOUSLY imporved, and convinced me to upgrade to a new unit. I disliked the price, but LOVE THE unit. TONS easier to read, even in bright sunlight, depth sounder portion much improved...twin beams really makes accurate reading, and fast readings (unlike older units).
May 08, 2011 | Lowrance Boating
HOW CAN I GET A JEPPESEN DATABASE UPDATE FOR MY LOWRANCE AIRMAP 600C?????
Dec 14, 2010 | GPS
I have a Lowrance 7200C GPS (marine) unit with a "Navico 041-0680-17 chip. It doesnt show the depth contours, is there an upgrade or do I buy another chip? and if so, what chip will be best for my unit?...
Not showing the Depth Contours usually means it doesnt have that programmed on the chip.
The best Chips Ive ever seen, used or worked with for the Lowrance's are the "Navionics" and Fishing Hot Spots. Both can be obtained from Cabela's...either retail or online. And normally go from 99bucks for last years maps to 199 for this years. Hope this helps.
Oct 15, 2009 | Lowrance Globalmap 7200c Gps 7" Screen...
Lowrance 3500 Digital Depth Guage flashed 0.5 continuously
If you have a glue in style transducer, be sure that the fluid has not leaked out of the cup. Otherwise, there really is no effective way to troubleshoot those without having known good parts to swap and try. If the cup is empty, it will need to be resealed with silicone (100% silicone) and then refilled with mineral oil.
Aug 26, 2009 | Boating
1. Turn unit off
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Lowrance LCX-15MT Ihave used this unit as a echo sounder from new just purchased LGC 12w arial to use GPS as well but keeps coming up(GPS module not responding)
Go to lowrance's website and run through their set up tutorial / instructions for the unit, there is also a software upgrade you can do online for the unit.
Sep 09, 2008 | Lowrance GPS
Hp pavilion ze4145 processor swap
From the HP references I have this laptop has an Athlon processor using Socket AM2. The Intel M chip is not compatible with your laptop.
Jul 17, 2007 | HP Pavilion ze4145 Notebook
Lowrance 5300C GPS Receiver Logo
95 people viewed this question
Top Lowrance GPS Experts
buzz flewhart
buzz flewhart
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
