My laptop doesn't write , the keyboard say that is working good , bad no even ,.i doesn't work is a dell windows 7 premiums
  • 374 Answers
Hi!
try to use other keyboard first with a usb port,then use it for trial if system is good.if good your key board is defective replace your key board by removing from your loptop.take a small flat screw driver on the side of keyboard insert the screw driver slowly not to break the edge,to lift the key board out of your loptop.or watch in youtube.com how to replace keyboard.hope this will help you a lot
Posted on Nov 04, 2012
  • 561 Answers
SOURCE: my laptop sound is not
try, going into control panel.
then click sound and audio devices
at the bottom of the next grey window click
speaker volume
then check that nothing is turned down or on mute.
I hope this was useful.
Posted on Dec 11, 2010
  • 10 Answers
SOURCE: my keyboard can not work
Actually not sure what your issue is here, again, you are not supplying enough information. Here is what I think you said, I have a VIAO with Win7 and it is configured for Spanish and it will not work for English because the keys on the keyboard are NOT mapped correctly. If this is the problem you will have to go into the Text Services and Input Languages dialog on Win7 and define any keyboards you wish to use. For American English there are a number of keyboards, but US and US-International are the most often used. If you find the dialog you may install new services for English (United States) and the corresponding keyboard layouts you wish to use. If you are using Spanish right now you should note that it will probably say Spanish (your country) - Spanish... You should be able to ADD a new language and keyboard layout. You can then use the language bar on the taskbar to select between Spanish and English keyboard layout when you want to switch between the two languages and key layouts. I use it often for European languages on Windows XP, 7 and also XUbuntu and it seems to work well on those without issue.
Posted on May 22, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: upgrading to windows 7
When you first boot from the win 7 disc there is a option to format or delete a partition.Do both.This will erase all vista information and allow only win7 to be installed.
Posted on Nov 04, 2011
  • 114 Answers
SOURCE: dell pc computer keeps freezing and crashing-have spoken to dell they keep telling me fixed but it is not
May be u need to reinstall a fresh copy of windows.or if u already done so, then it might be a hardware incompatibility
Posted on Mar 15, 2012
  • 247 Answers
SOURCE: Windows 7 Home Premium on Dell Optiflex 760 desktop
This model was released in the Vista era but is not horribly old. I have updated some hardware from XP/Vista to W7.
However Dell does not list W7 as this model predates the OS.
http://www.dell.com/downloads/emea/products/optix/Optiplex_760_Spec_Sheet_en.pdf
However, microsoft lets you run compatibility tests with the Windows 7 Upgrade Advisor. See: http://www.microsoft.com/en-us/download/details.aspx?id=20
I would estimate your chances of success as very good - but check the MS Advisor.
Posted on Oct 15, 2012
Some keys laptop keyboard not working
Rarely does anything good come from dropping a laptop. It could be a loose connection or the keyboard needs replacing. Open the laptop and reseat the keyboard connection.
May 28, 2013 | ASUS Recertified - U46 Series U46E-BAL5...
My dell inspiron beeps 20 times at sturtup
I wonder if you have a keyboard issue. Most times the constant beeping means the keyboard is bad, but it doesn't normally boot or revert back to 5 or 4 beeps.
May 08, 2012 | Dell Inspiron 6400 Notebook
Thespacebardoesnotworkatall-canyoutell?Allotherkeyswork.
Plug in a USB keyboard to your laptop and test the spacebar on it. If it works, then the laptop keyboard may be bad.
Try this:
1. You may just need to reseat the keyboard. In other words, disconnect it from the motherboard and then reconnect it to see if it fixes your problem.
How to:
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/
2. If step one doesn't work then buy a new keyboard and install it.
Sep 05, 2011 | Dell Inspiron 1525 Laptop
How can I run my old copy of Monopoly from Infogrames on Windows 7?
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
Feb 13, 2011 | Infogrames Monopoly 3 for Windows
Will 64-bit Wiindows 7 work on dell inspiron 1300?
Hi.
Dell only support this laptop to XP with drivers, I therefore doubt you would even get the 32 bit version of Windows 7 to work on this
Dec 30, 2010 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
I have aDell Inspiron laptop. How do you use the touch pad to drag. Why doesn';t tapping work for me?
ok.. it is as easy as visiting any download site of your choice e.g isohunt or thepiratebay, and search for [ Synaptics Touch Pad Driver-14.0.11.0] for download...install it and enjoy...
Jul 22, 2010 | Dell Black 173" Inspiron 1764 Laptop PC...
@ sign not working, is there another key for this?
you can try ur onscreen keyboard for the @ sign.
you can find it in Accessories--->Ease of Access----------> OnScreen Keyboard
you can even type the following commands in RUN
in Windos Xp: type OSK
in windows Vista/win 7 in search box : type OSK
good day
May 29, 2010 | Dell Latitude D600 Notebook
Keys qweruiop not working on startup (first 15 minutes or so) on physical keyboard on HP G60-533CL Notebook PC running Windows 7 Home Premium (64-bit). Keyboard Driver Standard 101/102-Key or Microsoft...
Take the computer to a qualified technician, who can replace the keyboard, as the least-expensive "try" at trouble-shooting.
Since a keyboard transmits "codes" to the motherboard,
e.g., left-shift-has-been-pressed, and left-shift-has-been-released,
and the motherboard interprets those codes, it is NOT likely that
the motherboard is misinterpreting the codes, especially given that
the "bad' letters are in a straight line on your keyboard.
Find an external USB keyboard, and plug it in.
If it works correctly in the first 15 minutes, then the problem is NOT the motherboard.
Jan 04, 2010 | HP Computers & Internet
I use dell inspiron 1440. today onwards the bt travel mouse does not connect to my laptop. how i rectify this problem
reinstal the driver for it and should work or check in start-my computer-right click manage-device manager -action -scan for hardware changes.
Dec 09, 2009 | Dell 5-Button Bluetooth Travel Mouse -...
Can dell inspiron 6000 handle windows 7?
Yes, i have a Dell Inspiron 6000 with 2GB in RAM and it´s OK. Better than Vista :-)
Windows 7.1.7600 build 16385 RTM Home Premium
Oct 11, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
