Question about Kenwood Chef Major A701 Food Mixer
My kenwood chef is not turning the mixing blades, although the motor is running fine. It's probably at least 35 years old! But has worked fine until now! Mixed my Christmas cake only 2 weeks
  • 3 more comments
  • David Hallas Dec 19, 2012
    Hi normally, the clutch dog and drive pinion are at fault on the 701 or the orbit cog on a 901 etc
    send me your email
  • jbrown50
    jbrown50 Dec 19, 2012
    Jbrown50@btinternet.com
  • Sallyanne Swan
    Sallyanne Swan Apr 20, 2013
    hi I have the same problem fo you have any instructions on how to do it?
  • Lindaak11 Mar 15, 2017
    Same problem here. Any help would be most appreciated. I love this machine & I want it to work for another 40 years.
Where do I send my Kenwood Chef food mixer to be serviced and repaired? I live in Bredasdorp Western Province
call the kenwood company spares department first and ask if spares are still available for that model, then ask for the address of a service agent in your area
if there are no spares then sending it any where for a service may get a reply that it is unrepairable because of lack of spares
Dec 01, 2016 | Kenwood Food Mixers
Tip
HOW TO CHECK YOUR KENWOOD MOTOR IF NOT RUNNING
WHEN A KENWOOD CHEF STOPS RUNNING THE FIRST THING TO TRY (PROVIDING IT HAS NOT SMOKED FIRST) IS TO TURN THE TWO SCREWS CLOCKWISE THAT FIT ON CORNER OF MOTOR SMALL SCREWDRIVER THROUGH PLASTIC COVER WILL DO IT AS THESE ARE A FINE TUNER AND CAN SOME TIMES VIBARATE LOOSE.****
on Jan 05, 2010 | Food Mixers
I have inherited an old Kenwood Chef mixer...I am unsure of the model but it is probably 30 years old, is white and the cover for the blender is blue. It was made in Australia, Elizabeth SA. I have...
Can't refer you to a dealer there but it is likely that only the motor's brushes need to be replaced. This isn't a difficult DIY job and the brushes shouldn't cost more than ~ $20 US.
You could also remove the housing covering the motor and see if the commutator is visible. This is a segmented copper cylinder and shouldn't be completely blackened although some signs of black is normal. The brushes ride on this cylinder and if the brushes have become too short, it can cause arcing and smoke. Clean that surface before installing new brushes and they too may smoke and cause rough running until they are worn in. The brushes can be had many places so you will have to choose one convenient to you:
Kenwood Chef Brushes
Jan 20, 2011 | Kenwood KM305 Stand Mixer
Just stoppped working and we are having dinner for 15 people today , tried the reset button. any advise please johanna
WHEN A KENWOOD CHEF STOPS RUNNING THE FIRST THING TO TRY (PROVIDING IT HAS NOT SMOKED FIRST) IS TO TURN THE TWO SCREWS CLOCKWISE THAT FIT ON CORNER OF MOTOR. SMALL SCREWDRIVER THROUGH PLASTIC COVER WILL DO IT AS THESE ARE A FINE TUNER AND CAN SOME TIMES VIBRATE LOOSE
Dec 03, 2010 | Kenwood KM300 Chef Stand Mixer
Kenwood acessories
Hello. your Kenwood Major is A707 ?
the new attachment for front and high speed outlet, not fit in A701/707 ..
Please visit our web site Kenwood Chef Restore in download section. you can download the compatibility of attachments
Regards
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Smoking/crackling Kenwood Chef A701...KM201
waiting to speak to Kenwood 1st as we understand parts may no longer be available for this model. Thank You.
Sep 06, 2008 | Food Mixers
There was a smell of burning, i.e. very hot wiring insulatiuon (?) on old Kenwood Chef Model 901. Could it be the motor or some other component, and can I repair it? If it is due to overloading due to...
Hi sometimes, its not the motor, maybe its the speed control, in this model same A701 its centrifugal system, if the capacitor or resistor not working fine, give this smell . you must give your Kenwood for repair or check
kenwoodchefrestore.co.uk
Aug 16, 2008 | Kenwood KM300 Chef Stand Mixer
How do I remove and refit a motor to my KM300?
What you need is a service manual which is difficult to get for any Chef regardless of the KM300. Ive got a KM310 model but the user manual is similar to this if it helps:
http://www.kenwoodworld.com/datasheets/KM336--KW89421iss2%20KM330-KM630%20%20English%20-0.pdf
Sep 11, 2007 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef Major A701 Food Mixer Logo
585 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
