Question about Fellowes Office Equipment & Supplies
Fellows laminator will not heat - Fellowes Office Equipment & Supplies
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Apr 29, 2015 | Fellowes Voyager 125 Laminator
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
. How do i fix my fellowes Mars A3 laminator it has jammed
Let it cool off for a while, then try reversing it. If it won't run it would have to be taken apart to clear the jam - a messy job! Fellowes does not usually consider these to be repairable but I would call them on their Toll-Free number to see what they can offer (800) 955-0959
Jul 01, 2014 | Gbc HeatSeal H425 Laminator
How to troubleshoot a fellowes laminator?
When plugged in, you can access it through your computer connections. From there, you can have the laminator scan itself for problems. If no problems are found, you can try to reset the whole thing.
Elisa Jed ' http://www.qprintfinishing.com.au
May 15, 2014 | Office Equipment & Supplies
I have a fellowes laminitor and it will not feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
A laminating sheet is stuck inside machine. You can't see it from either end and machine smokes when turned on now. It is a Fellowes EXL 125-2.
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Sep 05, 2008 | Office Equipment & Supplies
37 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
