Question about Frigidaire FEF336BC Electric Kitchen Range
Thanks, however I have a new issue
You were right. There was a short. When I pushed the element back it contacted the back cover. After replacing the wire connector and powering up I am getting no heating. Did I blow a fuse or damage the board ?
    Sergeant:
  • 311 Answers
Thats possiable.but most common is the breaker trips[house breaker]push both 50 amp stove breaker all the way to off.push ,off direction to make sure resetts,then to on.if still no work you can do visiual inspection,but other wise need volt meter
Posted on Jan 04, 2009
HOW DO I INSTALL BROILER UNIT IN THE UPPER OVEN?
pull the oven out and remove the mains plug. On the rear of the appliance you should see a cover that would be where the back of the element is. Remove the cover and you will see two electrical contacts and two screws or bolts that hold the element to the back of the oven. Remove the wires and then remove the element. Replace with new element, tighten the wires firmly whilst supporting the element but don't over tighten. Some have push on tags and they are susceptible to arcing and burning off where the wire enters the connector. If this has happened to yours, you may not need a new element, but make sure you use heavy duty STEEL crimp connectors.
A quick look at the part confirms my educated guess based on GE broil elements.
Thermador Range Stove Oven Broil Element 00143944
Nov 11, 2015 | Thermador SEC302 Electric Double Oven
Maytag Range MER5875QAS Problem Need Help
it could be a fuse or some wireing it also could be the heat monitor in the back of the oven
Jan 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Water tank not heating
Either your heating element is broken or the pressure switch. With a votage tester test the leads going to the heating element. To do this you need to remove the right side panel and test the heting element leads. You should have power going to this, if you do and its not heating you need to replace the hating element. If no power check your pressure switch, by removing the cover and with an insulated screwdriver push the contacts together and check the voltage at the heating element.
Dec 16, 2012 | Nuova Simonelli Aurelia Espresso...
take a putty knife and at each corner of the front panel about 4" in from the corners are clips push them in with the putty knife to release them,then raise the top cover and lean it back against the wall,then remove screws holding the front cover and remove door switch wires attached to the door switch,then pull top of door toward you and lift up to remove off gussets and set aside,the element is located on the lower right side remove wires to all thermostats and element then remove screw holding element housing,replace element in element housing by splitting housing in half after removing screws,reverse procedure to re-assemble unit
Nov 29, 2012 | Kenmore Dryers
Exactly wher eis the ele element located on an Atwood 6 gal Mod 6-E (LP & Ele)? Do you have to remove the entire water heater to replace the element? .Thanks...Richard.
There should be access from inside RV to get to the back of water heater. Make sure you have the hydro breaker shut off. On the back there is a cover where hydro wires etc, go in to. That cover has to be removed to give you access to element. Once cover is off, you should see element down low. You may want to test for voltage at element, then check switch ( on side or top of cover) and reset at ECO, (push in on little reset in center of ECO ) just in case one of them was the problem, and save changing the element.Then carefully test for voltage at element terminals. If voltage there and not getting hot replace element.
Feb 14, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Dryer model DE05-US2 will not turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dryers
How can i change my omega oven element and how to i find out how many watts the old element is
Hello,Is your element fixed to the back wall by (1)Two Phillips head screws or (2)the ends of the element are about "8" apart and held in with 2 clips.Switch off the power on the main switch board marked RANGE,STOVE OR OVEN.
In case of (1) unscrew and take the element out,pull off the 3 push on connectors,get new element and do it in reverse.
In case of (2) get a small screwdriver,push the clip just above the tube from the element going to the back and the clip should jump out,do the same for the other side,lift up the element a 1/4 and pull it out carefully not to loose the cable as they are very short
Thanks
May 28, 2010 | Ovens
I have a Frigidaire self cleaning electric oven. I heard a two pops and this tripped the circuit breaker. I can't reset the circuit breaker because the pops occur again and trip the breaker again. Any...
Sounds like a shorted wire or something grounding.
Slide out range and unplug and take off bake and look around for a short either at the bake or broil element ot at the terminal where the cord connects.
Oct 01, 2009 | Kitchen Ranges
Element won't heat on Masterbuilt smoker
You have to buy new cabinet. Take a look on amazon... here: Amazon com Masterbuilt cabinet. I hope this was helpful. cheers
Oct 19, 2008 | Masterbuilt ESQ30B Smoker
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
97 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
