I need a remote control for a Lasko heater model #5592
4 Suggested Answers
SOURCE: lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Posted on Nov 10, 2008
SOURCE: Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Posted on Dec 10, 2010
  • 4736 Answers
SOURCE: i do not have a
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Hope this helped you.
Posted on Mar 09, 2011
Can I purchase a new remote for an unidentified heater?
Heaters : Target
www.target.com/c/heaters-home.../-/N-5xtuk
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Lifesmart Meduim Room Infrared Heater w/Remote - Space ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Heaters - Overstock Shopping - The Best Prices Online
www.overstock.com/Home-Garden/Heaters/.../subcat.html
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Jan 27, 2016 | Heating & Cooling
Will not turn on when activated
You have a bad remote or the buttoms on the display aren't working.
Dec 05, 2015 | Lasko Heater Tower With Remote Model 5132,...
How do I fix a lasko tower heater model number 5586 always shuts off
it sounds like a sensor at fault or the control card if fitted
Dec 18, 2014 | Lasko Heating & Cooling
I have a lasko model 5362. the lower control knob is cracked. i need a replacement. please advise.
That model is under recall. DISCONTINUE USE
Also models 5132, 5345, 5364, 5420, 5532, 5534, 5566. For recall information see:
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
Dec 03, 2010 | Lasko Heating & Cooling
Codes for toshiba universal remote number ct-90302
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 26, 2010 | Toshiba CT-90157 Remote Control
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
