Question about Kyocera Finecam S5R Digital Camera
Non-functioning camera My Kyocera S5R has frozen in the lens-extended/flash up configuration, and the display is non-functioning, as well. Inserting fully recharged batteries in attempt to shut it down makes no difference. By pressing the power button it will give off its sound as if it is starting up, and on one occasion it did retract the lens and power the display, but in rotating the dial and selecting another function it went back to its zombie state. Is this a dead camera or is there a solution?
  • 2 more comments
  • Dale Matlock May 23, 2007
    A call to Kyocera was finally returned and the tech indicated that it was likely a problem with the lens mechanism, probably in the gear box, and that the only fix would be to replace that. Of course, without sending it in there's no way of knowing if that expensive repair is the actual solution.
  • DemiDee Dec 13, 2007
    I have the same problem!
  • reghody Jun 03, 2008
    Nothing seems to fix the problem.
  • hirendvashi Aug 11, 2008
    I have exactly same problem with my S5R.
  • 883 Answers
Open the unit. look for anything electrical disconnected from sloppy factory
Posted on May 21, 2007
SOURCE:
My d80 stops functioning and shows F----!! Any help would be great thanks.
This is usually a lens issue. If the lens is not properly attached or the lens is a non-cpu lens it shows this error. If you are using an older non-cpu, you have to switch to M-mode to use it.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
My sony camera keeps informing me to "turn camera off and on again
This happends when the auto focus or the flash bulb or capcitor is desfucntional I would check this into a shop to see witch it is you might want to take the battery fully out then put it back in but I think there is more of a issue here then that.
let me know
please do leave feedback and ratings for your free answer today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
My flash is firing, but my photo is not recording the flash output. The photo is dark as though there was no flash.
  1. Make sure the contact on the flash and the top of the camera are clean.
  2. Check the exposure compensation (+-/-) on the camera and flash. It should be set to 0.0
  3. Make sure the camera is set on P, A or S or manually set to the correct synch.
  4. Make sure the camera is compatible with the flash.
  5. Check camera lens function to make sure the aperture is opening and closing correctly. Some older lenses (AIS, AF or non-G lenses) will need to have the aperture locked on the largest f number.
  6. Make sure the lens is compatible with the camera.
  7. Take lens cap off camera
If none of this works take everything to a local camera shopp for them to diagnose the problem and send off for repair.
Nov 15, 2009 | Nikon Speedlight SB-600 TTL Flash
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Cannon powershot sd900 lens will not close
work for about 50% of lens errors, but they're worth a try. The list includes:
  1. Remove the batteries and wait a few minutes
  2. Try pressing and holding the Menu, Function, Function Set, or OK while turning on the camera, or otherwise find a "factory reset" option.
  3. Try turning the camera on without a memory card inserted
  4. Place the camera flat on its back and turn it on while holding down the autofocus button, to try to cause the camera to attempt autofocus while the lens is extending
  5. Blow compressed air in any gaps around the lens - or use a shop vac
  6. Use a thin piece of paper or a needle to dislodge any visible bits of grit
  7. Gently tap the camera in an attempt to realign jammed mechanics or dislodge particles (obvious warning: could cause further damage)
  8. Gently push or pull the lens barrel, as a last resort (again, potential for further damage).
Dec 02, 2017 | Canon PowerShot A75 Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Error message is F--
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Jul 03, 2008 | Fuji FinePix S2 Pro Digital Camera
Help with frozen lense
the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 29, 2007 | Samsung Digimax S700 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
Kyocera Finecam S5R digital "flash close"
You forgot to open the shooting flash on the top of camera
Nov 24, 2007 | Kyocera Finecam S5R Digital Camera
Kyocera Finecam S5R Digital Camera Logo
149 people viewed this question
Top Kyocera Cameras Experts
Harrie
Tony Parsons
Tony Parsons
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
