Question about HP EliteBook 6930p Notebook PC
Linning occur on the starting of the laptop
When i start the laptop different lines are shown on the l.c.d only when they boot the laptop. how i can minimize them or remove them
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
I think Your lcd have problem on its hardware. You can change your hardware (LCD) in your nearest shop.
Posted on Nov 03, 2012
What do i do when my emachines laptop loops the title screen
Is it on a boot loop ?
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Boot in safe mode or the operating system equivalent. Windows, Unix/Linux and Mac operating system have a mode that will load the minimum software needed to boot. This is a standard approach in troubleshooting, as it only supports the minimum hardware needed to complete the boot into the operating system. Once you are logged into the computer, device drivers can be updated, software removed and so forth. To boot into safe mode in Windows, hit the "F8" key when the computer first starts up to get a submenu. From there select a boot option. Many choose "Safe mode with command prompt" as this will go line by line through the boot process, allowing you to isolate where the problem might be. To boot into a different run level in Unix/Linux, it depends on the version of Unix/Linux, but most have the option of a "recovery mode." During boot hit the "Esc" or "E" key and select the mode appropriate such as "drop to root shell," etc. If you have the ability to get into command shell, enter into run level 1 (single user mode) by typing in "init 1." To start in safe boot on a Macintosh laptop, hold the "Shift" key as it boots up. This forces a disk check and loads minimal software in efforts to complete the boot process, much like the other operating system's "safe modes." Check to see if your laptop is overheating. Laptops have a greater likelihood of overheating than desktops. Either touch the laptop or download an application such as Mobile Meter to check laptop temperature. If it is running hot, try using canned air to clear out of vents, etc. Also, elevating the laptop off of its resting surface allows greater airflow in and out of the laptop
Feb 18, 2013 | Computers & Internet
Dell Inspiron 1750 will still not start up after new motherboard has been fitted
I think the new motherboard dosen't matchmaking with your Laptop .So , you should change it
Dec 03, 2012 | Dell Inspiron 1750 Laptop
Acer aspire one model zg5 is in a loop of erecovery management and gives error message cannot format the object drive
If you mean laptop is in boot loop ?
hope this helps
Nov 27, 2012 | Acer Aspire One PC Notebook
Launch startup repair
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Nov 27, 2012 | Toshiba Satellite C655-S5049 Notebook
At first it freeze but when you continuing restarting it, it come but now it cant come again
hope this helps
Oct 22, 2012 | Acer Aspire 3002LCi Notebook
Dell Latitude D630 Laptop, no Bootable device when trying to start laptop,but hard drive works find on other computer usb drive
It sounds like you have lost the boot manager file. The boot manager is a file set up by Windows to stop hackers from getting in to your system and if a problem occurs it is deleted by Windows.
When you try to boot and the desktop gets to POST, teh Dell page, quicklt hit F8
When, and it will take a few goes to get the timing right, you are succesfull a DOS menu will be shown on your screen
Select repair and follow the instructions.
Hope this helps.
Nov 23, 2010 | Computers & Internet
When are turn on my laptop.. It shows only windows screen with "press f2 to change set up" and "press f12 to change your boot order" at the bottom of the screen. Later, it turns out to a blank screen.
Hi, you haven't said what operating system you have, but here are two options. Restore windows with your windows CD. Or you can boot into safe mode by pressing the Del or ESC key during initial boot, select start in safe mode, from where you can reset your operating system to an earlier time before the problem. Both of these will not loose any saved files.
Aug 07, 2010 | Acer Aspire One AOA110 Linpus Lins Lite...
Upon start up thescreen display is verticle lines and the start up screen never display
This usually indicates that the screen is a little busted. If you have a warranty, send it in right away to have it replaced. The whole screen has to be replaced, it has nothing to do with the video card. If you do not have warranty, cost of replacing may be equal to that of the laptop.
It could be from opening or closing your laptop to harshly or from excessive pressure on the screen (if, for example, you pack your laptop in a backpack along with 30 lbs of books) or from one hard hit.
Just to make sure which component to blame for your display, you can try to do the following tests with your laptop:
- When ever the lines are occurring, fix it to an external monitor (you should have a port). If the distortion do not occur there, your display is gone.
- Check if the lines occur during booting. That is, before any drivers are loaded. You need to look carefully. If not, it may be a faulty driver. Do you know how to look for the correct driver for your machine?
- If distortion occurs during booting, it may be faulty graphics card. To check it further, you can take a bootable CD/DVD and boot from that, and see if the display is correct; if not, the the graphics card is gone. This is very unlikely in your case.
Hope it helps. Do let me know, for anything else needed.
Sep 10, 2009 | IBM Computers & Internet
STUCK ON START PAGE,CAN'T GET TO DESKTOP
Most likely a Windows software problem. Could be virus caused. Try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options.Use the arrow key to select "boot using last known good configuration". If that works, you're done. If not, try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options. This time select "boot in safe mode". The laptop screen will look different but will still allow you to run your laptop. Click on the "Start" button, then "Help and Support" and then "Undo changes to your system using system restore". Click on "Restore" and then select a date shown in BOLD when your laptop was running fine. Have the laptop restore to that date. After restarting, you should have full functionality. If this doesn't work, you may have a failing harddrive. Try reinstalling Windows. If it fails during loading, your harddrive is most like failing and should be replaced. If reloading solves the problem, you had corrupt software probably caused by a virus attack.
Sep 07, 2009 | Dell Inspiron 1525 Laptop
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Nov 02, 2007 | iLO 2600 Television
HP EliteBook 6930p Notebook PC Logo
27 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
