Question about Electrical Supplies
I have a Coleman Maxa 4000 generator circa '88-'90. I recently found out that they sold an optional quieter muffler for it. Is it still possible to get one? Can I use a generic muffler? Also,
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
  • 57 Answers
SOURCE: I have a Coleman powermate Maxa 5000 ER generator
http://www.powermate.com/productmanuals.php?cat_id=3
Try this link.
Posted on Jul 30, 2009
  • 394 Answers
SOURCE: I have a coleman generator Maxa 5000 ER
"I" is on.
Posted on Jan 31, 2010
  • 5603 Answers
SOURCE: Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Posted on Apr 16, 2010
Testimonial: "Thanks for info. I had it solved. I found the 130uf 200V rated cap was bad. 12 volts to the brushed did re-energize the field, power is operating. TY"
westburyauto
  • 66 Answers
SOURCE: Hello, I'm trying to get an old Coleman Maxa 5000
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Posted on Dec 22, 2010
Testimonial: "Advice was right on the mark! Well written advice too!"
Why does muffler get red and stays red while running?
Red muffler? that can be caused by restricted cooling airflow over the engine, excessive carbon build up in the cylinder, and also way too lena a fuel mixture. Also be cautious of engine overloading
Dec 14, 2012 | Coleman Powermate 4000 Watt Generator...
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Trying to find out about the muffler for a powermate pm0401850 generator is there anything that will make it quieter? anita8575@yahoo.com
hi, I was able to buy a State park approved muffler that was way quieter.
Approved for campground use.Found it at a parts house. I know you will be able to find one I just cannot point you in a direction. Maybe try colemans web site. Good Luck
Jan 29, 2010 | Coleman Powermate Premium Plus 6250W...
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Engine surge up and down
Cleaned the carb again and set idle stop screw up
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
