Question about Vivitar V4000 Zoom 35mm SLR Camera
SLR light meter
I believe my cemera's light meter is broken. When you push halfway on the shutter release, one of three symbols should light up in the view finder... red plus sign, green circle, and red minus sign according to light. No matter how I adjust the brightness, the red minus sign lights up. I've tried a new battery, and still no change. I've gone to photo shops who have reffered me to send my camera off to some place that MIGHT be able to fix it, and others that have very little experience with non-digital cameras. I am no expert by far, I would just like to know if the problem is able to be fixed.
    Problem Solver:
  • 40 Answers
Hmmm well its getting power.... surely the lens is on correctly. Since the camera seems to be working, one option is to get a hand-held light meter.
Posted on May 24, 2007
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Nikon f3 shutter release and light meter
there are a number of things that could be causing this and none of them are good. The impact could have torn the main circuit. If it hit on the rewind side there is an expensive glass disk (glass is used for temperature stability) called a FRE that has contacts on it for the ASA and aperture information to be sent to the main circuit. This is easily broken. You may also have damaged the shutter speed unit or its flex.
Jun 01, 2012 | Nikon F3 35mm Film Camera
How do i turn on and operate this camera?
There is no dedicated power switch. The meter turns on when you press the shutter release button halfway.
You can download the manual at
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Feb 05, 2011 | Vivitar V3800N 35mm SLR Camera
I installed new batteries in my camera. I turn the on knob and camera does not operate. Something wrong with power system Contacts are clean, new batteries Nikon N2020
"Turn the on knob"? You turn on the N2020 by lightly pressing the shutter release button. Do the meter indicator LEDs inside the viewfinder light up when you lightly press the shutter release button?
Dec 26, 2010 | Nikon N2020 35mm SLR Camera
How do you turn on a sigma SA-7n film camera??
I don't know about the SA-7, but the SA-5 doesn't have an on/off switch as such. Pressing the shutter button halfway activates the autofocus and turns on the light meter. The camera switches off after six seconds of inactivity to conserve batteries, though the shutter can still be released accidentally. Turning the mode dial to the "L" position will lock the shutter and prevent accidental release.
You can find a manual for the SA-5 at http://www.butkus.org/chinon/sigma.htm . It's not ideal, but it should help you get started.
Dec 25, 2009 | Sigma SA-7 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
I followed the instructions in the manual, and put new batteries in + side up. Then I continued with the rest of that step, but I did not see a flashing red LED light anywhere. I do not understand what to...
A few things to try, based on my FG's operation: - The most obvious- are your batteries good? Correct type? If they are: - When all is well the red LED metering lights will appear in the viewfinder window on the right side, in the range of shutter speed numbers. - The red LED metering lights are only activated when you press the shutter release button (halfway). The lights go out after a few seconds if the shutter button is not held down. Just tap the shutter button to reactivate them. - The shutter speed setting dial must NOT be on B (Bulb) or M90 (non-electronic Manual mode) if you want to see the red LED metering lights. The lights do not operate on these two settings because metering is irrelevant here (you'd be doing the metering, not the camera). - If you're in P (Program mode) the lens aperture must be set all the way to the smallest setting (usually f22 or f16, depending on the lens). If not, you'll only see blinking lights at the top and bottom of the shutter speed range on the right in the viewfinder. That's a reminder to set the lens to the smallest (highest numeric) aperture.
Hope these help. The FG is a great little camera.
Aug 14, 2009 | Nikon FG 35mm SLR Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Vivitar V4000 Zoom 35mm SLR Camera Logo
473 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Jax Planet
Jax Planet
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
