Question about Sanyo SR-3660S Compact Refrigerator
The freezer door is missing - Sanyo SR-3660S Compact Refrigerator
Look for a gasket for the freezer on the main door of the unit. This model may not have a separate freezer door. If there are hinge pins for a freezer door and this is new, contact whoever sold it to you and report the damage. Otherwise try Amazon, eBay or Samsung to buy the missing part.
Posted on Nov 03, 2012
Led light wont come on
When you remounted the freezer door you might have missed or damaged the switch (button) when you moved the unit. Check that and replace it if necessary. That should fix the problem.
Nov 14, 2013 | Electrolux Vacuums
Whirlpool Refrigerator Model #ED5LHEXTD00 ice maker is defrosting. The flap inside the freezer door where the ice maker dispenses is missing, Can we order a replacement?
Hello, Thank You for using FixYa. I will be helping you today.If the door is missing it will melt the ice and frost up the freezer or temp loss,The part number is 2180353 if you need all the parts its 8201649
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool Refrigerators
I am experiencing frost build up on the top part of the door as well as the top part of the inside of the freezer. all other areas are fine
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
Jan 28, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Water dispenser wont work
no water in door for 2 days, i placed a small heater in front of the freezer door and within 15 min.i heard a crackling noise in the door and a few drips of water came from the water outlet in the door. i got a glass and and once again we have water in the door. thanks
Dec 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Beeping coming from the freezer every minute or so
Usually a frig will beep if it thinks the door is open or if it is too warm. Since everything is cool, then check to see if the door switch is turning off the light or if there is a magnetic sensor on the bottom of the freezer door jamb that may be missing or there might be a sensor missing on the door itself. Ooorrr, the there may be a problem in the freezer and things just haven't melted yet. You need to pull out the bottom drawer in the freezer and look into the slots in the back panel of the freezer. Make sure that you can see coils in there and not a bunch of frost. If everything checks out ok, let me know and I will go over some other things.
Dec 05, 2008 | GE GSS25JEMWW Side by Side
I have a hotpoint freezer 8721. The top compartment is consistently freezing up really quickly, which makes it difficult to close the door,which ultimately means im forever defrosting the freezer. I have...
Check your door seal gaskets on the freezer door. Your model number is incomplete but I take it that this is not a frost free model. Placing a dollar bill between the frame and the door in the closed position should give resistance when slid or pulled. If not your door seal gasket could be bad or your door out of adjustment.
May 09, 2008 | Refrigerators
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Sanyo SR-3660S Compact Refrigerator Logo
127 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
