SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
SOURCE: i have an LG fuzzy logic top loader, black pieces
This is probably the seal around the door and drum. Professional work is required.
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
