Vangaurd vn3000 nat gas heater
Heater will light and go completely out in 2 mins,ive replaced the ods....need help can keep buying parts
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: have a problem
Over the summer months dust gets into the ODS safety pilot. You must blow out the dust and whatever is diminishing the dlame ans causing the premature shutdown. CLICK HERE for photos of where you must clean.
Posted on Feb 09, 2009
Need gas valve for Empire 7088-2 (Nat Gas) heater
Get on computer and type in surplus gas heater valves,or used,or gas valves for --name and # of valve,i can't find the name but there's a Canadian co.that almost has everything gas..years ago they bought up a lot of American companies stock when going out of business of changing product types,there's got to be other companies that have done the same,,ask the wikipedia of out of business gas companies,who bought them out or there parts,someone has them,or a universal valve.
Nov 22, 2012 | Empire Heating & Cooling
Have to keep lighting water heater
Clean air intake. Change thermocouple.
American Standard appears to be Bradford White or Rheem product from the one image that appears on the AS site.
Air intake located on side of unit funnels air to arrestor screen located under the combustion burner.
Remove burner and blow out screen with compressed air.
If this is Rheem product, then also inspect for broken glass vial that indicates high-temperature FV event, which might also require other parts to be replaced.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
Sep 27, 2012 | American Standard 40 Gallon Natural Gas...
The heater will shut down after about ten seconds.
Graham there are a couple of things that could be causing what you described.
The Oxygen Depletion Sensor (ODS) which is part of the pilot assembly could be clogged with dust, lint or pet hair. When this happens, the ODS reads the oxygen level as unsafe for operation. Using canned compressed air with a straw nozzle (like you clean your computer with) to blow out the ODS and the pilot tip should solve the problem.
Also, if the air louvers of the cabinet of the heater may also be clogged. Keeping them clean is important.
The Thermocouple, which keeps the pilot lit, may have failed. In which case it will need to replaced.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 09, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a everdure 6 burner gas heater. its pretty old and works sometimes. the problem is that it take a while to turn on and once it started it just turns its self off with in minutes. this happens...
Your flue-less gas heater may simply need a a good interior cleaning and servicing. From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be clogged with dust, lint etc. The ODS is part of the pilot assembly and constantly reads the oxygen level in the room, when the heater is in use.If the oxygen level drops to 25% the ODS shuts the unit OFF by closing the gas valve. This can occur if the ODS is dirty, because it's falsely reading the oxygen level.
One other thing that can mimic this problem is a faulty Thermocouple. With age, they wear out. It's also a safety feature that controls the gas flow to the pilot.
Everything I have mentioned is repairable. But, if you want to make it a DIY project, it will require some dismantling of the heater cabinet to access everything and replace parts. If the heater is as you say "pretty old", you may want to consider buying a new heater. Sometimes, it's just not worth the time and effort to repair an old heater.
Hope this helped you to troubleshoot and solve the problem.
May 27, 2011 | Heating & Cooling
Hello. I fire it up. It runs one minute and shuts off. Piolet and all. I start it up. Runds 5 min and same thing.
Here's the problem. The Oxygen Depletion Sensor (ODS) which is part of the Pilot is clogged with dust, lint and/or pet hair. When that happens, the ODS sensor reads the oxygen level as unsafe for operation and shuts the unit down, by closing the gas control valve. This problem occurs quite often when the heater doesn't receive Annual Maintenance and Service.
To solve this problem yourself. You will need to dismantle (remove) the front part of the heater, carefully remove the log set and you will be able to access all of the interior workings that need to be cleaned. A Shop Vac with a brush attachment and a can of compressed air with a straw nozzle (like you clean your computer with) works well in completing the clean process. Be sure to vacuum all of the interior of the firebox, as well as the burner(s). Be sure to clean/vacuum thoroughly. While you have the logs out, vacuum them on all sides. To clean the pilot, use the can of compressed air with the straw nozzle attached and blowout the pilot tip with a quick blast of air. Look down the pilot from the tip (where the flame comes out) and about 2/3rd's of the way down, you will see a small hole in the side of the pilot. That's the ODS Sensor. Place the tip of the straw nozzle just barely into that hole and give it a quick blast of air. You will probably see debris blow out the other side. Once you have completed all of this, start to reassemble the heater. Be sure to install the logs identically to the way they were original installed. Failure to do this correctly, will cause sooting problems. If in doubt, consult your Owners Manual. Once you have completed reassembling the heater, light the pilot. Be sure to hold the Pilot Control Knob in for one minute, before releasing it and turning it to ON. If everything now works as it should, pat yourself on the back, As you just completed what's called "Annual Maintenance". This should be done every Fall, before firing the heater up for the season. If you have house pets, you should do this twice a season. First in the Fall and again in mid-January.
If all of the above did not solve the problem, the Thermocouple, which is part of the Pilot Assembly has started to fail and needs to be replaced.
Hope this helped you solve the problem. Please let me know and be sure to rate my response to you. Thanks!
Apr 14, 2011 | Procom QL300RYLA Heater
I replaced the thermalpile in my wall heater and when I turn the stat up the pilot goes out what do I do
The air intakes of the burner may be clogged or you wired the "thermopile" to the wrong contacts on the control valve.
You didn't mention if this was a vented or vent-free heater. If it's a vent-free heater the same things listed above still apply. However, it may be that the Oxygen Depletion Sensor (ODS) which is part of the pilot may be clogged with dust, lint and/or pet hair. When the T-stat calls for gas to light the burners, the ODS senses there's not enough oxygen for safe combustion and closes the gas valve.
Also, gas pressure to the heater may be low. Only enough to keep the pilot burning, but not enough to ignite the burner(s).
Hoe this helps to head you in the right direction on further trouble shooting the problem.
Mar 02, 2011 | Heating & Cooling
Can not get the pilot light lit again
It could be the electrode or the ODS pilot assy. that you need to replace. It really depends on the type of you unit you have. If its made by Desa( Comfort Glow, Vangaurd, etc) or ProCom check out Master Parts, they carry these parts. 800.446.1446 or www.masterparts.net. I hope this helps you!
Feb 26, 2010 | Desa International GWRN18T Infra-Red...
DAYTON HEATER 60,OOO BTU
Hi, I do not no the age of this unit, but when a furnace is installed, it is set up for Nat. gas., and they most always leave you a small package taped to or near the gas valve that has the spring and L.P. orfice in it, in case it is needed. See if you can find it first. If not, get all of the numbers from the main gas valve (mgv) and from the unit heating plate attached, b.t.u.If you can't find it, at the top of the main valve, you will see a brass colored screw slot.May be aluminum. Turn off gas and power. Remove the threaded screw cap and remove all small parts, a spring, a plastic or maybe aluminum round orfice, about 3 pieces. Keep them in the order you remove them.Replace with the L P Parts if you have them. If not, you will need to take the parts and all numbers you can get from valve and unit to a appliance parts store to purchase.You shouldn't have to adjust the gas pressure as now days they are the same for nat. and L P.About 3.4" of water colume. Thats a different name for pressure. Very easy for you to do. Good Luck, Shastalaker7
Dec 07, 2009 | Dayton Gas Furnace Heater
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Have a problem
Oct 04, 2008 | Vanguard International VN30B Infra-Red...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
