Question about Beko Washing Machines
My Beko WM 8127W is stuck on a program and i can not cancel it out it wont spin or empty the water out or move the clothes is still in it any help plz .
    Sergeant:
  • 264 Answers
Check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Posted on Nov 03, 2012
  • Beko Master
  • 744 Answers
Hi if your beko WM 8127W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
  • 1294 Answers
SOURCE: beko wahshing macnine wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 11, 2008
  • 5 Answers
SOURCE: Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Posted on Feb 07, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Washer filling up with too much water
Hi
This is a fault with the water pressure sensor - it doesen't sense any.
8 times out of 10 the sensor is fine - but the pipe that connects it to an air chamber has a hole or is disconnected.
Turn it off (water and electric) and unplug. Remove the top, and check small hoses that go down the side of the machine. Replace any damaged hoses (take original to spares shop)
Replace and reconnect.
If you cannot see anything wrong - take the hose off anyway that connects to a sensor on the end of it. Take it off the lower end only- check it over fully, and blow down it. You should hear a click from the sensor. A test meter would help to see if it is functioning.
Replace sensor if faulty.
If it still produces the same fault - you may have a control board fault.
Please post back here if you cannot solve it for further test procedures.
Thanks for using Fixya.
Posted on Jan 10, 2009
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
  • 41 Answers
SOURCE: hoover 600mb doesn't spin
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Posted on Sep 03, 2009
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
Beko washing machine wont drain or spin water stays in drum
Jul 01, 2009 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Sep 05, 2008 | Indesit W 123 Front Load Washer
Beko wahshing macnine wont spin
May 11, 2008 | Washing Machines
Washing Machines Logo
489 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
