1999 Aiwa stereo seems to be stuck in stand-by. Will not turn on.
Aiwa model# CX-NA888U manufacture date July 1999. Home stereo with 3 disc CD changer and dual cassette deck seems to be stuck in stand-by. I plug it in and the demo plays on the display but when I push the power button (or any other button) nothing happens. Please help.
  • datboiikris7 Apr 05, 2009
    i have the same problem
aiwa cx-na508
Posted on Jul 28, 2008
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
try here
Posted on Jan 18, 2009
SOURCE: aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
SOURCE: Which Aiwa remote control unit to buy.
Went to manufacturer's website.
Posted on Dec 12, 2009
  • 998 Answers
SOURCE: I have a Z-L70 compact
This trouble is very common to this model the system control ic is already damage I suggest that you should bring it to the service center and this parts is not available to the market. Good day and best regards.
Posted on Aug 07, 2011
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Where can i get a free user guide for aiwa cx-nmt520
gm rick hoffer go to this site then type in your model number good luck....
Jul 08, 2012 | Aiwa Audio Players & Recorders
Is it possible to install a 3.5mm headphone jack input from an ipod directly into the car stereo? I don't want to use an fm transmitter. My '04 Mazda3 comes with the 6-disc cd changer but no tape deck or...
I have a 2003 Mazda MPV that has the stereo that you could add a cassette deck or MD to...I do not have either, but there is a button for it. I found a guy on the internet that made a chip that plugs into the back of the radio and has a 3.5mm jack on it that will play when you push the cassette/md button on the radio. It is great....sounds just like one that came from the factory.
Oct 29, 2010 | 2004 Mazda 3
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Feb 23, 2010 | Aiwa Audio Players & Recorders
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
email add;
Nov 12, 2009 | Aiwa Audio Players & Recorders
447 people viewed this question
