Question about SATO M84Pro Label Printer
It is saying cutter error. What is that and how can I fix it?
I have cleaned the machine and turned the power off and unplugged it to reset however it still says cutter error and will not print.
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
How I fix an error code on a LG wm2669hna washer that says TE error
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
May 17, 2010 | LG WM-2277HW Front Load Washer
My canon MP620 has a code B200 error, & i have no idea what this is or how to fix it. Any help appreciated.
Turn off the machine, and unplug the power cord of the machine from the power supply. If the problem is not resolved, contact your Canon service representative.
May 08, 2010 | Canon Office Equipment & Supplies
I have a Canon Pixma MP500. Everytime I try to print, I get an error message that says the inner cover is open, but it's not. I've turned the machine off, unplugged it, confirmed the cover/flap is up and...
Hello sir;Lift up the inner cover , on the right hand side there have a round hole look down the hole you will find a piece metal, try find some stick to push down that's door switch, if the message disapear, means door switch is OK, then have make sure your reset procedure is correct, close all cover turn switch off , UNPLUG power cord, wait for about one minute plug in and turn on the power again, it should be work.
Feb 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Receiving E,2,7 Error messages. Can't clear. help please!
Canon support says reset machine by holding power button for one second until the display shuts off. Wait ten seconds, press power button - allow machine to completely turn back on. Otherwise, they say your printer may need repair.
(If holding the power button will not turn device off, you may unplug the power cord as an option).
Nov 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Error 0xd05d010d on hp 5610
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET
Jan 18, 2008 | HP Officejet 5610 All-In-One InkJet...
6000
I had this Check 6000 when I first got the machine. The problem was that I did not lift up the top cover (where you put the paper in). As a result it locks the carriage and creates this error. Lift up the cove at the top of the machine, then turn the machine off and on again and 'Hey presto" your problem is solved.
Dec 21, 2007 | Canon FAX-JX200
SATO M84Pro Label Printer Logo
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
