Question about Samsung SGH-a777 Cell Phone
My Samsung SGH-A77 won't boot up past the AT&T splash screen
Whenever I hold down the power key to turn it on, I get the AT&T splash screen for a couple seconds and then the screen goes blank. Neither replacing the battery or SIM card or plugging it in helps. I'm not sure what caused it to stop working--it seems to have happened spontaneously.
3 Suggested Answers
SOURCE: glitching screen on samsung SGH a777
MY SAMSUNG SGH-A-777 SIM NOT UNLOCK.I TRY IT BUT NOT SUCCEFUL ME,PLEASE HELP ME.
Posted on Jun 13, 2010
SOURCE: My samsung sgh-u900t seems to be working except
Fred - my phone did exactly the same thing in Dec 09. I can see it is turned on - I can even log in by looking at the bottom screen (which lights up when a text message comes in) but the top main 2.2 inch screen is black (with a light lit behind). Is it the same as yours and, if so, how did you resolve it?
Posted on Aug 13, 2010
Samsung sgh T669 won't turn on
Dear Brother;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 06, 2012 | Samsung Gravity SGH-T459 Cell Phone
My samsung sgh 1997 will not turn on. just a grey battery blinking
5.Wait 10 seconds.
Step
Thanks
Oct 24, 2012 | Samsung Infuse 4G ATT Unlocked SGH-1997 3G...
My a167 won't turn on
5.Wait 10 seconds.
Step
Oct 06, 2012 | Samsung SGH A167 Cellular phone - AT&T -...
Yamaha P-250 Stage Piano won't boot up...
Yamaha pianos go through a self test on start up. This could indicate a problem on the main motherboard.
Try a hard reset.
Hold down top C key while turning on.
Wait for it to start up, if it still freezes its time to take it to the repair shop.
Mar 27, 2012 | Music
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
My samsung sgh-i780 has frozen and no service on it and the spb menu is not working
1. Power off the phone
2. Hold down the begin call and end call buttons (green & red)
3. Press and hold the power button
4. Once the phone's status LED turns red, "RELEASE" the power button but KEEP the other 2 pushed. Very important to do this !!!!!
5. You will get a prompt to press the space key to format, or any other key to continue
May 02, 2011 | Samsung SGH i780 - Microsoft Windows...
Glitching screen on samsung SGH a777
Jan 31, 2010 | Samsung SGH-a777 Cell Phone
Samsung mobile phone error codes 3d010017
my mobile phone SGH-U708E will shut down without any reason suddenly while making a phone call, it will show the error code"3D010017" after restart it.
Aug 06, 2009 | Samsung SGH-t219 Cellular Phone
Samsung T629 stuck at splash screen
Take your sim car out and try using these codes to reset the phone.
*2767*2878# and *2767*3855#
Your phone software could also be corrupt.
If you go to samsung you may be able to update the firmware in the phone over the internet.
If all else fails have the phone re-flashed by a technician.
Mar 02, 2009 | Samsung SGH-t629 Cellular Phone
Samsung SGH-a777 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
