Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch Nexxt 6400 has flopping drum-can move it back and forth while spinning by hand. Tech sez broken shaft gear--get rid of it.
Tech gave this diagnosis over phone without viewing machine.
  • seanaobrien May 19, 2014
    Sounds more like worn out shock absorption cylinders. Replaced mine and works better without the banging sound
    Sergeant:
  • 264 Answers
This has had its day mate get rid of the machine as you can not repair as the drum is sealed on that model ok
Posted on Nov 03, 2012
barkencoa
  • 3463 Answers
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 23, 2010
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
SOURCE: Washer stopped. E04 beeps but won't spin or continue any cycle. Have shut off machine but only makes a strange sound.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
http://www.fixya.com/support/t1589624-bosch_nexxt_dlx_washer_open_round_panel
img_0001
img_0002
img_0003
Posted on Jul 26, 2009
  • 38 Answers
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Posted on Jul 28, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Posted on Jun 18, 2010
  • 414 Answers
SOURCE: Bosch Nexxt Premium washer shaking like crazy
Check that the w/m is level (not necessarily with a spirit, just that it doesn't rock and roll), lock the foot nuts up to the machine. Check the pump filter and outlet pipes for blockages. A machine will be noisy if it taking to long to discharge the waste water. If you have moved the w/m and are in a hard water area, you may have dislodged built up lime and that has created the problem, run a heavy duty descaler (designed for w/ms) through the w/m.
Good luck
Posted on Jul 08, 2010
Testimonial: "Good, practical advise. Thank you!"
How to check error codes on Bosch Nexxt 6400
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 29, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Tip
UNABLE TO SHIFT INTO GEAR LEVER STUCK, LOOSE OR ONLY SHIFTS 1 WAY (either up or...
LEVER STUCK, LOOSE OR ONLY SHIFTS 1 WAY (either up or down)
Check that its not just the gear pedal either stuck on its pivot shaft due to corrosion, & that it is not just spinning round on the gear change shaft
If stuck in gear, try rocking the bike back & forward while moving the pedal up & down
If not then its probably the gear selector mechanism - hopefully on the accessible part.
If the gearbox only shifts 1 way then its probably just a broken / dislodged spring on the claw mechanism.
Remove the right-hand engine cover & check that the shift shaft operates the claw (which turns the gear selector drum) & that all springs etc are OK.
Otherwise its on the internal part of the selector mechanism either the shift drum is stuck or more likely the shift forks are worn or broken. Either way it will require a full engine strip
Ride Safe
Bike-Doc
on May 12, 2010 | Motorcycles
Hi there:
Bosch Nexxt 100 series front load washer will not spin. The machine will go through the entire wash cycle from wash-rinse-spin-finish but does not spin. I tried a separate spin cycle and nothing happens....
Just going on these symptoms, you may need a new control/timer.
Inside the control /timer are electrical contacts, and when your machine gets to that part of the cycle, the contacts are not closing to allow the cycle to complete.
If you have circuit board, you will perhaps need a new one of those.
If you do not, probably a control/timer assembly.
If you type "SeasPartsDIrect" into you computer's search engine, and then type your complete model number into the blank when you are asked for it, you may look at the schematic and see whether you have a control / timer or a circuit board.
God bless your efforts.
Oct 08, 2017 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer doesn't agitate or spin. How can I tell if it's the belt.
Hi
Try to move the tub by hand. If it is not moving easily then small clothing or any other foreign object is stuck there and you'll need to clean it. If it is moving by hand then it is due to a loose or broken/worn out drum bearing itself that has gone bad and should be replaced. If there is a humming or rattling noise then the belt has gone bad and needs to be replaced. Hope this helps....please post back for further assistance.
Daniel
Feb 05, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water runs into drum but drum does not spin. after 10 mminutes washer beeps
If the drum does not move at all, I would suspect a broken drive belt, or worn motor brushes. Check beep codes/error codes in your manual, for a better idea of problem area.
Aug 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have Bosch Nexxt Premium WFMC6400UC Front Load Washer. It noted a suds or pump blocked error. I was able to access the pump cleanout at the bottom of the washer and remove a small wire that was lodged....
macmarkus :)
Jun 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water will not drain out of washer (bosch nexxt 6400). Will spin if on cold wash but not on spin. makes a clicking noise while trying to drain
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Mar 14, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
388 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
