Question about Creda W120VW Front Load Washer
Washing machine tripped ouy.
Put the machine onto a wash. As I walked out of the room the I heard it trip out. Then the door would not release. I have fitted a new door lock switch however the machine still will not start a cycle.
    Sergeant:
  • 264 Answers
There is a track blowen on the programer thats has to be repaird fisrt if you can solder then get back to me ok
Posted on Nov 03, 2012
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Wmf540 beeps
Not sure your entire question but if no cycle is chosen or running and you close the door and the power trips then it is definitely your door lock mechanism. This is located to the right of the door behind front panel. If it tripped out in the middle of the cycle and by closing the door you are restarting the cycle then it will depend on where in the cycle you are up to. Of course it can always still be the door switch itself I don't usually find them tripping the power. If the machine starts the fill but trips out it is likely the inlet solenoids. If the unit fills some and then trips it is likely the motor. If the unit fills washes and then trips it is likely the drain pump. If the unit fills washes drains and then trips it is likely the motor. Of course at any of these points it can be any of the pc boards. So if you know where in the cycle it trips this will narrow down the choices.
Jul 08, 2013 | Washing Machines
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
I have a kenwood washing machine, about 20 minutes into the wash cycle a trip siwtch on the fuse board trips. If I move the cycle onto a spin cycle it works fine
A make and model would help us help you! Which "switch" is triping? What is the water level in the tub when it trips? What water level do you have your machine set to? We need some specific information from you to be able to give you the best advice.
Jun 08, 2011 | Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
My washing machine keeps tripping the main switch on my fuse box, i replaced the fuse but its still doing it. I ahve washing trapped inside and its in water, its important i get it out. Whats wrong with...
Frequent tripping means a short in the machine. Disconnect from the supply and locate the drain plug somewhere at the bottom of the machine. You should be able to drain off the water and then open the door manually. Be prepared for a lot of water to be released. The fault will have to be fixed by a service engineer.
May 02, 2008 | Washing Machines
Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
need to know a little more really but here goes, if you remove the top and the drive belt is still on then it will be as straight forward as the motor brushes at fault they will need replacing as this is a common fault on these machines. hope this helps
Mar 06, 2007 | Hotpoint WMA48 Front Load Washer
Creda W120VW Front Load Washer Logo
41 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
