Question about Refrigerators
Water leaking from bottom of whirlpool fredge model ed2khaxvb01
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
peyton32034
  • 410 Answers
SOURCE: Second new Whirlpool fredg. that will not stay cold
whirlpool had a bad run of evaporator fan motor (the fan in the freezer section) it is a simple fix and a good service company should pick up on it. since the unit is new have lowes send out a different serice company than the first one mention to them about the air not blowing good to the refrig section and if the fan motor is running fast enough. they should replace the fan motor with part number 4389177 this is a whirlpool part.  Let me know how it turns out. thanks Peyton
BTW whirlpool is one of the best so be patient and let em fix it you wont be sorry...
Posted on Mar 14, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
erpaalai
  • 999 Answers
SOURCE: Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Posted on Aug 10, 2009
capsman
  • 111 Answers
SOURCE: Water is leaking from the bottom of the fridge.
Some water dripping under the refrigerator is normal. There is supposed to be a drip tray to collect it, and there is not so much that it can't evaporate. Check to see that the tray is still there, in the right place, and not cracked. If the drip tray is full of water, then you have another problem. If your air is humid, you would get more water during the defrost cycle and the water in the drip tray wouldn't evaporate very fast. If your freezer door seal is not air tight, you would get more water to defrost. My guess is, the drip tray is out of place or cracked.
Posted on Sep 11, 2009
I have Whirlpool refrigerator model number ET20GM that is leaking water from bottom. What is the solution?
There is actually a small drain hole on the bottom of the freezer where condensation and such goes. Take out your bottom drawer/shelf and look in the back bottom of the freezer.They can get frozen over. A pro would use a steamer to clean it out and Melt the ice. But you can use some hot water to get the job done a bit slower. There is also the possability the Ice maker is leaking. But Check the drain first.
Oct 01, 2014 | Whirlpool Refrigerators
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
The fredge space became warm, the freezer was OK.I have found out that the problem is in the clogged drain hole in the bottom of the freezer. After I had defrosted the refrigerator, the cooling of fridge...
Sounds like you are having a defrost problem. If the problem was only with the drain hole, the refrigerator section would still maintain temperature and not get warm. The fact that when you defrosted it, it started working properly, indicates a defrost problem. After defrosting manually, it will work properly for a few days.
What is the make and model of your refrigerator so i can tell you how to gain access to evaporator and drain hole.
Feb 20, 2011 | Whirlpool Refrigerators
Water does not shut off in ice-maker immediately
maybe but check the icemaker to see if the fill switch is working and the timer might be off. In an old unit it is sometimes better to replace it than put a bunch of time and money into it they are not bad priced these days
Aug 23, 2009 | Refrigerators
I have water dripping from my freezer into the frige
Drain line on back of fredg is cloged This allows the water from the freezer after defrost to go to a pan under the fredg Take the line off and blow air in to it to unclog Be carefull not to mak a big mess
Jul 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Mar 14, 2009 | Refrigerators
My fredge rm 2652 not working
Between 1993-1996 dometic used a yellow epoxy filled circuit board that went bad pretty quickly if you have the yellow filled circuit board rather than the green one it is most likely the circuit board
Jan 09, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
