Question about LG 32LG30 32 in. LCD HDTV
I have lg 32pc51 model.in past month when i try to turn it on from stby mode(red led),the led switches to green or yellow and there is no picture.only if i take out the ac cable,wait for few secs and then plug it in,and then attempt to turn it on ,it starts ok.i am suspecting the power supply.what do u think?
  • 2 more comments
  • Tony Nov 03, 2012
    REplace the power supply module.
  • udirn1 Nov 03, 2012
    Can u direct me to a site who offers such spare part?
  • Tony Nov 05, 2012
    LG.com
  • Tony Nov 05, 2012
    Yes.the possibility of power supply module went bad or th fuses .
  • 127 Answers
The Ac power cord or the wall socket.
Posted on Nov 04, 2012
  • udirn1 Nov 05, 2012
    I already replaced the cord and it didnt help.I suspect the capacitors on the power supply module-ill try to open the casing and see if they are swolen
  • 1,238 Answers
Try to go to shopjimmy.com
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
SOURCE: LG RZ-23LZ40 no Picture
Thanks Jaime867
Best send repair manual.
I have pics to show / identify problem but I cannot attach to my reply. Parts defective are: 4532M x 2 (UC2 & 3), diode next to diode RC22 & cap C35 and IC6 (cannot see part number). Board number is YPNL-M007B r1.0, also recognized L.G. Phillips part number: LC230W01-A2
My hands are not as steady as years ago to do surface mount solerering but my wife can as she has done this before being electronic equipment assembler.
As stated before I need to find source of what I suspect is short that had blown these components.
I bet a replacement board is more expencive than a new LCD TV!, but I want to resolve this prob and maybe help others...LG too.
Thanks Heaps Jaime867!
Cugar63
Posted on May 25, 2008
jmgldsmth
  • 1869 Answers
SOURCE: i have a lg plasma,and the problem is it comes on
your power supply is shorted; remove it from the set and, have a TV shop repair it if you are unable to do the repair yourself.
any good shop can do the repair easily and, much cheaper than the manufacturer you can find the power supply by looking to where the power cord enters a circuitboard that will be the power supply
Posted on May 28, 2009
  • 197 Answers
SOURCE: tv won't turn on - power SUPPLY OK
bad main pcb
Posted on Jun 07, 2009
  • 41 Answers
SOURCE: I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Posted on Dec 18, 2009
TV cannot turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Action-3: Replace the main board!!!
Mar 25, 2017 | Hitachi Televison & Video
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
LG 32LG30 32 in. LCD HDTV Logo
267 people viewed this question
Computer Repairing
Computer Repairing
